Installed Pop Charger/Service engine light?
Old Sep 24, 2001 | 06:16 PM
kaniksu's Avatar
I instlaled my pop charger today. Started the car and the Service Engine Soon light came on and won't go away.... I talked to someone else who said this is something he has heard happens often. But I have never seen it mentioned. Has anyone else had this happen and how can i get the light to go away?
Alec
Old Sep 24, 2001 | 06:29 PM
JeepRage's Avatar
Re: Installed Pop Charger/Service engine light?
did you unplug the sensor in the old Airbox, and leave it disconnected?? you gotta reconnect it, even if its loose in the engine bay, or the check engine light will go off almost instantly.
Old Sep 24, 2001 | 06:37 PM
Daniel B. Martin's Avatar
Alec
Perhaps you disconnected the harness from a sensor. If so, reconnect it and reset the Engine Control Module. Read the Sticky Thread Important: ECU Diagnostic Trouble Codes. The first post in that thread points you to a Web site which provides detailed instructions for this.
Old Sep 24, 2001 | 06:47 PM
BRIGBOY's Avatar
Re: Re: Installed Pop Charger/Service engine light?
To which sensor are you referring?
Old Sep 24, 2001 | 06:52 PM
yourmove's Avatar
Alec
Did you instal the stillen pop? If so, did you have to extend the wire to temp. sensor?
Old Sep 25, 2001 | 05:57 AM
Sonic's Avatar
Re: Re: Re: Installed Pop Charger/Service engine light?
Either the Ambient Air Temp Sensor or the MAFS.
Old Sep 25, 2001 | 06:21 AM
Disconnected sensor
Agreed. If the car runs well it is the Ambient Air Temperature Sensor (a/k/a Intake Air Temperature Sensor). If the car runs poorly it is the Mass Air Flow Sensor.
Old Sep 25, 2001 | 08:22 AM
kaniksu's Avatar
The car runs fine and everything is connected. I believe I just need to reset the ECU for the light to go away. It was the MAF Sensor that I unplugged during installation, that was the only sensor I dealt with during the process.
Thanks!
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
Flores94
Aug 11, 2015 12:53 PM
bassmann
Aug 3, 2015 07:53 PM
