Help installing aftermarket fog/driving light
I'm trying to find a hole in the firewall to run the wires for the on/off switch inside the car. Can't find it and don't want to do any drilling or run it through the door opening cause it looks like a hack job. Any suggestions? Also, people who have fogs installed in the valance area on a 95-96 max; which brand are you using. I prefer the rectangular style. The one I purchased, the depth is too long and sticks out too much cause the vertical bars on the valance get in the way when mounting. Thaks in advance for any response
Re: Help installing aftermarket fog/driving light
or you can drill a hole thru the fire wall & put a rubber grommet in
Thanks, I found a hole with a rubber grommit dead center and it was unused too. The switch has been fed inside the car but I'm still having problems installing the mounting brackets for the fogs. I don't want the hassle of cutting the verticle bars on the valance to make it fit but I also don't want the fogs to stick out too far. Maybe I can find fogs that aren't so long in depth. Any suggestions?
Team STILLEN
Aug 10, 2015 04:29 PM
kirkhilles
Aug 8, 2015 10:53 AM
