Install Question
Old Oct 4, 2001 | 10:01 PM
gma6188
Install Question
How do you go about removing your door panels.
I own a 98 max SE and I can get everything off but the
door handles. I cant remove those and therefore cant remove
my door panel. HELP ME OUT PLEASE!!!!!
Old Oct 4, 2001 | 10:40 PM
ereet's Avatar
Heh
the little rectangle things around the doorhandle right?
Those things are trademark nissan. **** that's hard to takeoff, and breaks if you do it wrong. Same with the corner lights, and plugs in the carpet in the trunk. Take a flat head screwdriver, and pry the end off that's closer to the front of the car. From there, you need to put the screwdriver in the top (or bottom) of the other end, and pry it off .. it should pop out after a little bit of messing around with it.
Again, it's standard nissan and will break if you use excessive force. Be careful
Old Oct 4, 2001 | 11:23 PM
max808's Avatar
Re: Install Question
It's tough to get it off. Use 2 small flat head screwdrivers if possible. It takes some force. Good luck.
Old Oct 5, 2001 | 04:50 AM
Micah95GLE's Avatar
After you pry the front of that trim ring loose a little bit, stick the screwdriver in above the trim ring about ½" from the back and push down. There's a tab that sticks straight up behind the door panel that you have to push down far enough for it to pop out. It's easy once you know the trick.
Old Oct 5, 2001 | 07:30 AM
breaux124's Avatar
http://www.geocities.com/artourb/max...ll_sheet_5.jpg
PH98I30
Jan 9, 2025 08:08 AM
JRod28
Dec 29, 2023 09:56 PM
mikekay
Aug 10, 2015 12:52 PM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
