If there's one thing badly designed about the Max . . .
Old Oct 12, 2001 | 08:23 AM
dwapenyi's Avatar
. . .it's the damn trunk lock. Mine always gets loose after a while. I have to un-screw the lock and tighten it down. I cna even see other Maximas on the street. If their tailights aren't lined up, I can tell their going thru the trunk rattles too. anyone have suggestions for a more permanent fix to this minor peeve??
DW
Old Oct 12, 2001 | 10:34 AM
mzmtg's Avatar
Minister of Silly Walks
Buy a toyota.
Old Oct 12, 2001 | 11:04 AM
Sprint's Avatar
Speed kills.. buy a honda.. live forever..
or you could just buy a GXE.. they all seem to be the sturdy models
Old Oct 12, 2001 | 11:07 AM
Jeff92se's Avatar
I'm needing a caw
it's the damn tree log suspension
Old Oct 12, 2001 | 11:08 AM
Sprint's Avatar
why don't you just tick your a$$ on out of here
Old Oct 12, 2001 | 11:13 AM
ny96max's Avatar
dwapenyi: can you explain further what part of the trunk latch is causing this? my trunk has the most annoying rattle whenever i hit bumps on the road, small or big.
Ill try anything to get rid of that noise
thanks,
Ant
Old Oct 12, 2001 | 11:16 AM
buss95max's Avatar
my trunk was making a squeaky sound for awhile. i sprayed wd40 on everything back there, and it went away.
Jeff92se's Avatar
I'm needing a caw
Me no tickie, read the stickie!
Old Oct 12, 2001 | 11:20 AM
dwapenyi's Avatar
The problem is that the trunk lock is secured by screws which are at right angles to the forces applied to them. The trunk lock moves up and down, but the screws are screwed in from back to front. You would see what I mean if you look at your trunk lock. What I did before was use some of putty solder stuff (forgot its name, its the stuff that lets you solder a connection without using a solder, in the form of a gray putty substance), put it on the threads, and tighten up. It would last about 6 months, then the trunk would be loose again I was hoping there'd be a more permanent fix out there.
That's what you get for having relatives who REALLY can pack a suitcase
DW
thanks,
Ant
Old Oct 12, 2001 | 11:40 AM
speedy-t's Avatar
Since we're talking about trunks.....
I seriously hate the location of the trunk release on the door. The darn thing is so easy to push in. On numerous occasions, I've reached down with my left arm into the door storage area and thunk, the trunk pops open. Then I have to get out and close it usually at a traffic light or in the drive thru. Maybe it's just me.
Old Oct 12, 2001 | 12:09 PM
ereet's Avatar
My trunk blew completely open one time when I first got my latest stereo setup and hadn't learned when loud was too loud .. I haven't done that in a long time since one of my subs is blown and the other is on it's last legs with a torn surround.
My car got wrecked the other month and I had the entire trunk replaced and I haven't had time to blow it open with a new set of subs then. Just get some bozo to plow into your car when it's parked for $7k worth of damage, and boom, all your trunk woes will be over. Kinda . Mine was crooked for the months prior to that, I never really found a good solution nor figured out how to adjust it enough so that I could get it to line up correctly. I think that's what you'd need to do though, mess with the screws on the trunk latch to adjust it so it fits good.
Old Oct 12, 2001 | 12:10 PM
JacksMax's Avatar
Originally posted by slammed95
it's just you.
its me too. Usually opening the door tho.
Jack
Old Oct 12, 2001 | 02:53 PM
ny96max's Avatar
um ok?? ill fiure something out
Old Oct 12, 2001 | 03:26 PM
iansw's Avatar
Strange...I have a 10" and 12" woofers, with a total of 900 watts going to them, and no rattle....at least not anything one would care about.
My dash rattles alot more than my trunk..
But I have a GXE...heh
Old Oct 12, 2001 | 05:41 PM
airmattdog's Avatar
Guy with the Orange Max
No, no, no. The worse design in how the Parking Break handle is pointed. I'm 6'5". That's the only thing that needs to be changed. Could it be bent inwards?
Old Oct 12, 2001 | 06:09 PM
NightRider's Avatar
Yeah, the emergency brake handle is rather intrusive. I miss the way my 3rd gen's e-brake handle sat in the middle of the console; out of the way. the trunk latch sometimes gets hit whan I get out of the car. Kind of annoying.
Old Oct 12, 2001 | 06:41 PM
Dasyce's Avatar
I like where they put the trunk release. It's better then accords, the have the same lever to do both the trunk release and the gas cover release, you gotta pull it up for the trunk and push it down for the gas cover lid. Or was it the opposite way around?
Old Oct 13, 2001 | 05:56 PM
j-95G's Avatar
call ms a redneck, (i AM from MS!!) but i'd try some j. b. weld. it is the second best glue ever made! (f-26 being the 1st) that should have the lock assy secured in about 15 mins.
Old Oct 13, 2001 | 11:08 PM
98BlaximaSE's Avatar
Speaking of poor disign, I would like to know who designed the cup holder that can't hold anything on a slight turn. Its impossible to get coffee and make it home with out spilling half the cup someplace.
Old Oct 13, 2001 | 11:13 PM
seouljah's Avatar
haha gxe's rule all
soloist3
Sep 2, 2015 12:59 PM
FlaMark
25
Aug 28, 2015 10:15 AM
JMag90
Aug 25, 2015 09:17 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Samedi
Aug 13, 2015 04:05 PM
