clunking sond when i brake
Old Sep 13, 2007 | 09:31 PM
anik151's Avatar
for the past couple weeks when i aplly the brake i hear a pretty loud thud is it that i need new calipers? i just installed brand new cermaic pads thinking that it would help but it didnt can any one help me ??
Old Sep 13, 2007 | 09:33 PM
thebballkid's Avatar
same here
same thing is happening with me....
Old Sep 13, 2007 | 09:35 PM
vqmaxman's Avatar
Originally Posted by anik151
for the past couple weeks when i aplly the brake i hear apretty loud thud is ti that i need new calipers i just installed brand new cermaic pads thinking that it would help but it didnt can any one help me ??
Is it coming the front or rear check where it's coming from then look at it carefully. First off did you work on the back or the fronts what ever you worked on just check if you setted the brake pads in well and the calipers and the rotors are well setted and all the bolts are tight.
sounds like you might have bad balljoints the one's that are connected to the knuckle.
Old Sep 13, 2007 | 09:37 PM
anik151's Avatar
it was the front but the sound was there befor i changed them
Old Sep 13, 2007 | 11:12 PM
randy021186's Avatar
i am about 90% sure it is the line....i always had the clicking sound but when i did the rear brakes about 3 days ago i looked at the lines...the lines run in a Y shape....my problem was that the left line came out of the bracket , so now there was about 1 inch play, and the line was hugging the frame when i had my friend pull the line..so i couldn't move the line becuase it was to tight and i was to lazy to readjust the line so i just kinda twisted it....
Old Sep 14, 2007 | 09:12 AM
RoM_PmP's Avatar
I had the same problem if i'm understanding you correctly..
I had to change my calipers..now everything is ok
Old Sep 14, 2007 | 09:41 AM
anik151's Avatar
i think u might be wright
Old Sep 14, 2007 | 11:03 PM
GStrength's Avatar
Quick question when you changed your brake pads, did you purhcase cheap *** auto zone brakes, and did you also replace your disc pad shims as well? When you drive over bumps can you hear your brake bads clinking.
Old Sep 14, 2007 | 11:12 PM
andrei3333's Avatar
u sure its your brakes and not the upper strut tower bearing or other suspension component clicking ?
just had to double check you know ?!?!?!
Old Sep 15, 2007 | 10:03 PM
anik151's Avatar
now that u mention it my suspension is pretty shot
Old Sep 15, 2007 | 10:14 PM
anik151's Avatar
i got these
http://69.0.158.19/live/N1010125340AKE.JPG
Old Sep 16, 2007 | 07:48 AM
jaymemaurice's Avatar
yeah I would make sure it is in fact your brakes... other things can clunk too when you stop... does it also clunk when you accelerate and turn without breaking (try both dirrections) and try listening with your windows down and up.
Old Sep 16, 2007 | 08:11 AM
hito's Avatar
I'm just going to throw this into the mix. Could be your swaybar endlinks. As I previously too had a clunking sound as I braked. Since you said you had that sound before even touching your brakes, could be something else other than brakes then.
But for me, it was my endlinks as someone had mentioned in a post I posted awhile back to help me with my clunking noise
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
