Please Help, 97 Max No Electric Power
Old Oct 16, 2001 | 08:19 PM
97SE's Avatar
I have a 97 Max SE, i have an aftermarket stereo and while driving my stereo shutoff and my clock on the car too. i looked at the fuses and none were blown, i looked in the engine for fuses and none were blown, i cant figure out what the hell the problem is, i even disconnect my stereo and when i turn on the car, the car clock does not turn on, does anybody know where i can check or what to do, Thanks....
Old Oct 16, 2001 | 09:16 PM
Eric L.'s Avatar
You mean you have no electricity at all? No clock? No lights?
If so, check the battery cable and terminal. If they look fine and are connected correctly, then check the voltage on your battery.
Old Oct 16, 2001 | 09:29 PM
Bags's Avatar
VG Ridah's Biatch Hoe
check for corrosion( battery acid build up ) on your battery posts. also check to make sure your ground off of your battery is solid. check the wires for breaks or bad connections. if the connections look black ,strip the wire and make a new one
lowpost99
Oct 26, 2025 06:53 PM
pktaske
May 6, 2016 07:49 AM
cruce91
Sep 20, 2015 10:23 AM
pktaske
Sep 4, 2015 08:40 AM
