Unsolved Problem
Old Sep 14, 2007 | 09:40 PM
95 Maxnout's Avatar
Unsolved Problem
After 2 recent visits to my mechanic,and several part replacements,my Max is still stalling out at stops and continues to run hesitantly.I just replaced 2 oxygen sensors,knock sensor and had the MAF cleaned.However,last night while I was driving home from work the check engine light came on,so evidently its trying to acknowledge the problem.I've also recently noticed that when it does run hesitant I can smell a light gas oder.I've finally decided to take it to the "stealership" next tuesday so I can FINALLY find out what the **ck is wrong.I was told that usually if you have to clean the MAF then you should prolly get it replaced, so I'm thinking that if I replace that part it will be good.What do you guys think cuz I'm really at the end of my rope with this.
Old Sep 15, 2007 | 04:46 AM
pmohr's Avatar
No more Maximas...
...you said the CEL came on, but said nothing of checking what code was thrown...
Old Sep 15, 2007 | 06:37 AM
67whitegoat's Avatar
Also, what was the original code or codes?
Old Sep 15, 2007 | 06:40 AM
If it is a bank lean code, MAF is a good bet.
Old Sep 15, 2007 | 07:51 AM
andrei3333's Avatar
why not take the car to the Nissan dealer and get them to check it out? if the mech cant fix it thats cause he does not know nissans all that well, i say go to the nissan dealer
Old Sep 15, 2007 | 08:25 AM
pmohr's Avatar
No more Maximas...
He hasn't even checked codes yet, it could be a very simple and cheap issue. Also, dealer diag charges alone are probably about the cost of whatever part he'd need.
Old Sep 15, 2007 | 09:57 AM
wayne937's Avatar
It certainly sounds like it is the MAF sensor to me. I would buy a Haynes Book at Auto Zone and check out chapter 6, section 5. It will tell you how to do a voltage check and a resistance check. A quote from Haynes says. "quote, a defective MAF sensor can cause surging, stalling, rough idle and other driveability problems. My daughter had this problem and after I replaced the MAF it took care of it. Good luck.
Old Sep 15, 2007 | 07:34 PM
95 Maxnout's Avatar
Yep,thats what I have planned.It goes in on Tuesday for diagnosis.I'm just hoping that they will be able to figure this out.My check engine light still goes on and off regularly so I guess the computer will store whatever codes that come up.Thank everyone for the input.If you guys have anymore info let me know.
Old Sep 15, 2007 | 07:38 PM
pmohr's Avatar
No more Maximas...
Why not take the 30 seconds and pull the codes?
Old Sep 15, 2007 | 07:57 PM
NmexMAX's Avatar
dot dot dot ...
Should be considered SOP
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
