Headlight Housing Question
Old Oct 17, 2001 | 12:21 PM
98se5spd's Avatar
I own a 1998 SE and it seems that at one time, before I purchased my car the right headlight may have exploded.
What I have now is broken glass, and a haze around the reflective portion inside the housing.
Is there any way of openning and cleaning/polishing the inside of the housing without running the risk of moisture getting inside, or am I looking at buying a new housing.
Thanks in advance.
Old Oct 17, 2001 | 02:28 PM
max808's Avatar
Re: Headlight Housing Question
You can clean the inside of the housing with soap and water. Let it dry completely. If you want to buy one, they are about $100 for the reflector type.
Thanks in advance.
Old Oct 17, 2001 | 04:33 PM
j_bryan's Avatar
Re: Re: Headlight Housing Question
i am thinking about getting a new headlight assembly for both sides (99 max). any idea on where to get these for cheap?
Old Oct 17, 2001 | 05:34 PM
Stillen_I30's Avatar
try searching an internet junkyard database...www.copartfinder.com is one of many.
Old Oct 18, 2001 | 05:16 PM
max808's Avatar
Re: Re: Re: Headlight Housing Question
I got my headlight housing from:
http://www.nissanparts.cc/
They have pretty good prices and prompt delivery.
Old Oct 18, 2001 | 05:18 PM
ny96max's Avatar
go to www.autodirectsave.com best prices for headlights and anything else for the max!
Old Oct 18, 2001 | 06:11 PM
amixam98's Avatar
Needs non-Maxima Friends
another site is www.tustinnissan.com.....try that...
Old Oct 18, 2001 | 07:06 PM
max808's Avatar
go to:
go to this thread and ask Tustin directly.
http://forums.maxima.org/showthread.php?threadid=64024
Old Oct 18, 2001 | 08:51 PM
MAXTOUT's Avatar
I have the same problem on the max I just got. I was looking at it today and it looks like there are shiny metal clips holding the clear lens to the backing housing. I didn't have time to take it apart, I rewired my blinkers and fogs instead, but if I do it this weekend I will post here how it went and what you need to do.
tED
Old Oct 19, 2001 | 04:18 AM
98se5spd's Avatar
tED
My fear is that if I open the lens, it will start getting moisture inside, not only making it look worse, but running the risk of blowing another bulb. I saw the clips too and it looks like there is some sort of sealer holding the lens on.
I was thinking of removing the bulb and trying to vacuum the glass out. But as far as the haze around the reflective part, not sure what I could do.
Good luck taking your's apart, and let us know how it turns out.
03VQMAX
Nov 10, 2015 03:39 PM
Vistance
Sep 17, 2015 05:17 AM
minsbang
Sep 11, 2015 08:48 PM
mpbclutch33
Sep 8, 2015 06:21 PM
sdotcarter
Sep 2, 2015 09:53 PM
