Does anyone elses timing chain make a clattering noise?
Old Oct 17, 2001 | 05:33 PM
emax02's Avatar
I am trying to figure out what I should do about my noisy timing chain. For the first minute of warm up in the morning my chain makes a rather loud clattering noise. Do any of you guys have this issue? If so what did you do about it? Also, does this mean my chain might brake soon? Thanks.
Old Oct 17, 2001 | 09:49 PM
emax02's Avatar
Anyone!?
Old Oct 17, 2001 | 10:12 PM
max808's Avatar
change oil
i read somewhere that if you change oil to dino and a little heavier it may help. try searching for the post. my old sentras chain did the same thing but sold it before it got worse.
Old Oct 18, 2001 | 12:28 AM
emax02's Avatar
Re: change oil
Thanks for the info, I would rather fix the problem rather then cover it up though. I think I am going to order new chains, water pump and and all tomarrow and do replace the chain myself. The install looks like a pain in **** though!
Old Oct 18, 2001 | 12:35 AM
asianpr3082's Avatar
I get this too but i also hear that it might not be the chain but the tension thing that puts pressure on the timeing chain but ask the dealer what this could be i am getting this noise too but it got louder so i dont know
Old Oct 18, 2001 | 12:37 AM
max808's Avatar
Re: Re: change oil
Take it to the dealer and see what they say, and don't fix it there. It may be a guide or tensioner or something? The timing chain was used so that it would last the life of the car. Unless, you've been towing boats or other cars frequently. I may be off base though.
Old Oct 18, 2001 | 12:48 AM
emax02's Avatar
Cool, I am not the only one! I think the thing you are talking about is called the hydraulic chain tensioner, I guess if air gets in the system in causes the chain to rattle. It takes a lot of work to get to that part though, almost as much work as replacing the whole chain. Maybe this raddle noise is exceptable? I don't want to have to fix it unless it is going to break my engine or something.
Max808, my car has 102K miles and I have never towed anything with it, I just haul **** with it to much .
Old Oct 18, 2001 | 06:31 AM
Sonic's Avatar
I would replace the tensioner. BTW, mine does not make that noise, only a funny cricket sound...
Old Oct 18, 2001 | 06:39 AM
95Max's Avatar
There is a TSB on all 95 for timing chain rattle. The fix is to replace the chain tensioner. This needs to be done. I am sure I don't have to say what happens if the chain jumps....minus one engine.
Old Oct 18, 2001 | 10:17 AM
emax02's Avatar
That stinks Thanks for the help!
Old Oct 18, 2001 | 10:49 AM
rockymtnmax
Most likely it's the Tensioner.
Many 95's and some 96's have this
problem.
I have not heard of anyone having a
failure with the Timing Chain linked to this.
I do believe it puts undue stress on the chain but
as I mentioned there are many people with well
over 100,000 miles or over 150,000 and never
messed with the chain.
however, I am not saying you should not fix it.
I also thought that the VQ engine is designed
in such a way that if the Chain fails it will
not ruin your engine, But i am not sure.
Old Oct 18, 2001 | 10:42 PM
Max4U's Avatar
My chain makes a clunk clunk noise but only at night and when the engine is real hot.
Old Oct 18, 2001 | 11:38 PM
max808's Avatar
timing chain
my chain made a rattling noise usually at cold start, not when hot. are you sure it's the chain?
Old Oct 19, 2001 | 01:17 AM
Autofanatic's Avatar
my timing chain (95'), when on cold start (mostly below 45 degrees), make a horrible rattling noise. i too was told the problem most likely originates from the tensioner, so i had several estimates done, much to my dismay. i was quoted anywhere from $800 to $2000 to fix this (NOT COOL). i am currently trying to find a way to get nissan to help me fix this problem, for the chain should NOT fail at 70k miles, or even 150k for that matter......
Old Oct 19, 2001 | 09:28 AM
Max4U's Avatar
Re: timing chain
Positive, brong it to the dealer and some guy told me that when the chain gets real hot it tends to stretch because its metal and metal expands to heat, but my noise is not loud only at nights when its real quiet and as I said when I run the car for like the whole day.
Old Oct 20, 2001 | 10:21 PM
SWEETSOUND2001's Avatar
Hondarydr
Dec 30, 2024 06:15 PM
CorollaULEV
30
Aug 9, 2021 08:11 PM
maxinout93
Oct 27, 2015 01:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
egali045
Aug 16, 2015 01:19 PM
