automatic rear view mirror
what do i need to do this mod? i just came back from the junk yard and they have a 96 i30 w/complete interior
Check out this recent thread. Let us know if you have any questions.
http://forums.maxima.org/showthread.php?t=536769 #7 |
http://www.fourthrock.com/maxima/mirrorinstall/
Please use the sticky's next time. They are there for a reason. Particularly this one for this question: http://forums.maxima.org/showthread.php?t=385887 |
Originally Posted by IlyaK
(Post 5951716)
Please use the sticky's next time. They are there for a reason. Particularly this one for this question: http://forums.maxima.org/showthread.php?t=385887 Thats a great write up, but I think he has a different kind of mirror. A 96 i30 mounted to ceiling not the window and it only dims so no external sensors. |
just came back from the junk yard and picked up the mirror, chrome interior door handles, intermittent windshield wiper switch, headlight/foglight switch and the wood inserts for the window switches. i think i got a good deal paid under $25. ill install all of this on the weekend.
I seriously wish there were some good junkyards here in CT...
theres four wires black, grn-blue, red-blue, red-yellow. blk & grn go together and red & red?
Originally Posted by maxim82
(Post 5952263)
that depends if u got the harness from the car... look at it closely.. changes colors when it connects to the mirror... so if u have the piece that comes out of the car.. then u need to connect the green wire with blue stripe... to..... red wire with blue stripe.. 12 volts Positive and the black wire..... to the red with yellow stripe.... GND..... OR if ur using the connector at the mirror then its red wire with blue wire.... 12 volts Positive green wire and black...... GND |
theres no harness its just the wires coming straight out of the mirror so it would be this right?
red wire with blue wire.... 12 volts Positive green wire and black...... GND do you mean.... red-yellow, red-blue= 12 volt grn-blue, black= ground is this right? or is there a cable that stays unplugged? |
autodimming mirror writeup: http://forums.maxima.org/showthread.php?t=335348
^ Hey, You found it. This really needs to be stickyed... or stickied... or stuck....it should be saved.
Thanks very much. I have had this mod on my car for a while but the mirror was loose and I didn't know how to tighten it. It's perfect now. Good info. |
THATS WHAT I NEEDED THANKS
glad to help!
© 2024 MH Sub I, LLC dba Internet Brands
