Antenna mast broken off inside housing - any ideas?
Old Sep 20, 2007 | 08:39 PM
bigd480's Avatar
My wife backed into a parking garage barrier arm (don't ask) and bent the antenna forward, cracking it. Eventually the antenna got weaker until I had to pull it off (pulled the entire mast off along with the entire nylon-tooth cable). The problem is there is still a piece of the last mast section inside the hole that won't pull out. I tried removing the bezel nut and going after it w/ needle-nose pliers but there isn't enough to really grab. Going back to the garage to look at it from inside the trunk but thought I'd post this first.
Old Sep 20, 2007 | 08:49 PM
bigd480's Avatar
OK fixed - got just enough contact w/ the needlenose to grab a bit of it and then constant twisting motion finally freed it (wouldn't pull straight up at all). Leaving the post here in case someone else has a similar issue - there was about 5" of the bottom section in there.
dcam0326
Sep 18, 2015 04:52 PM
DBear
Sep 14, 2015 08:33 PM
Violator
Sep 9, 2015 10:14 AM
