guys help with HID they wont fit
Old Sep 22, 2007 | 04:14 PM
xkazik's Avatar
ok after i came bak from work today i tryied to put in my hids but they wont fit .. i have no idea why the cuts on the bulb are exactly the same ? did anyone had that problem before ? on maxima97
Old Sep 22, 2007 | 04:18 PM
Dave H.'s Avatar
Brand?? Who did you buy them from? More information will be helpful.
Old Sep 22, 2007 | 04:20 PM
xkazik's Avatar
Banbo Hid .. and a local store ..
Old Sep 22, 2007 | 05:43 PM
LiGhtSoUt's Avatar
are u sure u got 9004 and not 9007
Old Sep 22, 2007 | 05:51 PM
xkazik's Avatar
yes i compared them and they look exactly the same as mine 9004
Old Sep 22, 2007 | 11:52 PM
97MaximaSE97's Avatar
Could you post a pic of your kit? Are the bulbs not fitting into the housings or is the kit not lighting up?
Old Sep 23, 2007 | 08:14 AM
xkazik's Avatar
http://i16.photobucket.com/albums/b1...k/DSC00023.jpg
hhttp://s16.photobucket.com/albums/b11/Xkazik/?action=view&current=DSC00022.jpg
they dont fit the housings ... no idea why
Old Sep 23, 2007 | 11:24 PM
are those rings around the base removeable? Looking at an old 9004 hid kit I have those rings shouldn't be there.
Old Sep 24, 2007 | 03:42 PM
D'MaX04's Avatar
it has to be the size..must be 9004 because i still have my 97 and the installation only lasted 5 min and it was a perfect fitment.
Old Sep 25, 2007 | 05:22 PM
shaft369's Avatar
New to *****
whats up man, i just put the same exact brand and size (9004) in my max yesterday,9-24-07...anyway what i had to do was widen the top slice in the plastic. when you the light with the bulb facing you and that blue stip on the bottom, u have to cut and widen the top slice in the plastic to make it wider to the right (when looking at it) in your headlight housing you will have 3 nipples, the new HID bulbs look the same as OEM but the cuts are a little off.....trust me, i put mine in but now i think i need to AIM mine lower or get projectors cause some people flash me....If this is a little confusing for you to read
Old Sep 25, 2007 | 10:12 PM
Buck96's Avatar
it's an Omen, its your car telling you to get projectors
Seriously thou check the rebased buld vs the stock 9004 and make adustments /w razor
Also: You may need to rotate them, ie the blue return wire my sit to the right/left not down.
on my old kit that was the case
Old Jan 30, 2008 | 04:22 PM
DVinacco's Avatar
i bought a HID Kit ebay from the same place my friend did for his LS and i got the 9004 conversion kit and they dont work...the kit came with ballast and light ther Zeus HID conversion kit....they from tripscustoms.com if anyone can help that would be great
Old Jan 30, 2008 | 04:54 PM
DVinacco's Avatar
thats how its hooked up i didnt have the bulbs in becuase i was testing it the bulbs are in the plastic tubes
Old Jan 30, 2008 | 07:12 PM
roggeezy's Avatar
+1 on checking the rings around the bulbs.
Old Jan 30, 2008 | 08:17 PM
Digitized's Avatar
DO NOT CUT RING
I had a 9004 HID kit once on stock 95-96 headlights.. if they are the proper ones ( 9004), they fit, you just have to push hard, the rubber ring will eventually "squish" to allow you to push the bulb in enough to screw the OEM bulb holder in place( the plastic ring)..
and when I am referring to "rubber ring", look at the pic below.. the red ring around the base of the bulb, that will "give in" after a few hard pushes.. and when you lock the plastic OEM ring to lock the bulb in place, well, the rubber ring you've squished to fit the bulb provides you an air tight / water proof seal...
do NOT cut it off or modify it..
Old Jan 31, 2008 | 10:20 AM
DVinacco's Avatar
the bulbs fit in my stock hole just my lights dont turn on
Old Jan 31, 2008 | 10:59 AM
kzoosho's Avatar
Check the lil blue connector.
Old Jan 31, 2008 | 03:05 PM
huyqvu's Avatar
get a set of calipers and check the diameter. i recently did an install where the hid bulbs were 1mm or so bigger. took a dremel and shaved it down a bit.
Old Jan 31, 2008 | 06:42 PM
DVinacco's Avatar
thanks lol
Cotozic
Jun 28, 2017 08:01 PM
rbuswell
Nov 12, 2016 04:11 PM
iflexsteel
Sep 15, 2015 03:37 AM
maxipower
Aug 21, 2015 11:10 AM
