Rear Caliper
Old Sep 27, 2007 | 05:37 AM
drgonzo's Avatar
Rear Caliper
Tried searching and was not having any luck. Is it possible for the average Joe wrencher to replace a rear caliper? My rear passenger is starting to stick and I want to replace it. I am somewhat familiar with working on cars. Used to do all the work on my Jeep. But the Max I have yet to really play around with.
Old Sep 27, 2007 | 05:41 AM
MadMaxSE-L's Avatar
Doggah Bite...
It shouldn't be that hard, just make sure you have a line wrench so you can get the brake line off, a regular open ended box wrench will round the head off.
Old Sep 27, 2007 | 06:42 AM
TsingTsaoNYC's Avatar
Pretty straightforward job. Just get remanufactured calipers. Not worth the hassle rebuilding them yourself.
Old Sep 27, 2007 | 06:44 AM
XJinCT's Avatar
<3's the all motor section
you dont need a line wrench or need to remove a brake line....just use a 14mm ( i believe 14) 6 point socket with the caliper still bolted...unbolt caliper...voila.
Old Sep 27, 2007 | 06:47 AM
MadMaxSE-L's Avatar
Doggah Bite...
Um, you are going to have to take the line loose from the caliper...
But I didn't remember if the line went directly into the caliper(double flare), or if there was a banjo bolt. It's been a while since I screwed w/ my rears...
Old Sep 27, 2007 | 07:02 AM
Banjo bolt for the rear. Just remember DON'T overtighten the banjo bolt when re-installing!
Old Sep 27, 2007 | 07:06 AM
drgonzo's Avatar
You need to bleed the brakes as well correct?
Old Sep 27, 2007 | 08:33 AM
cardana24's Avatar
Blown
oh yes. and it's not a very hard job like everyone else is saying.
Old Sep 27, 2007 | 08:54 AM
VQ30DETT's Avatar
easy job takes no more then ten min side. make sure have some to help you bleed the brakes. remove e-brake cable, if i remember it's on bolt on the caliper. good luck
Old Sep 27, 2007 | 09:24 AM
drgonzo's Avatar
Thanks everybody.
Old Sep 27, 2007 | 10:45 AM
XJinCT's Avatar
thats not a line, its a brake hose wth a banjo fitting. ive never seen a caliper with a hardline connected to it. unless its a drum brake system, then obviously there would be a hardline to the wheel cylinder.
Old Oct 9, 2007 | 08:02 PM
nafddur's Avatar
It's definitely a brake hose, cause the caliper floats.
And a rear caliper replacement IS a very simple job.
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
bbsitum
Sep 11, 2015 04:55 PM
beerman1378
Sep 8, 2015 02:19 PM
