how do you know when to replace control arm?
Old Sep 28, 2007 | 04:08 PM
aznstormin's Avatar
Sometimes when I turn to the right, there's a horrible scratching noise coming from the passenger tire area. Like metal scratching against metal. Also it happens sometimes when I brake. It's not the brakes or caliper. They're both ok. ~2 weeks ago I changed the strut insulator and bearing. That and the endbar sway link have been changed (ever).
One friend says it could be the lower control arm. I don't know when that'll need to be replaced (I'm sure soon though...)
Another says that it could be the axle / axle bearing.
Neither of them have heard it, I've just described it to them as I have to you guys.
Axle and everything looks ok (visually).
Any ideas? It makes me cry everytime I hear it...also kinda embarrasing.
Old Sep 28, 2007 | 07:17 PM
19Maximus98's Avatar
It sounds like it could be the dust guard behind the brake rotors. If they are rubbing the rotor you will hear a grinding sound coming from that tire. To fix this, simple push back (Away from you) on the dusk shield until it no longer is in contact with the rotor. You do not want to do this after driving the car as the guard will be HOT!!
The control arm doesn't go bad per say, but the bushing on either end do. If the bushings were to go bad you would hear more of a thud sound or metal on metal rattle not scratching and your handling would be sloppy.
Hope that helps
Old Sep 28, 2007 | 07:25 PM
aznstormin's Avatar
Yeah, I thought so too. But it also happens even if I'm just braking - like at a traffic light or stop sign. Took the tire off today and didn't seem like it could be that dust guard.
Old Sep 29, 2007 | 03:29 AM
mastercater7's Avatar
VQ35 FTW
I have had a tiny rock get stuck back there, just take the rotor off. Control arms wouldnt cause this problem and need to be changed when you run into curbs
Old Sep 29, 2007 | 06:13 AM
aznstormin's Avatar
Hmm..I'll take off the rotor and check for anything. I'm still curious if it's highly possible that it could be the axle? Possibly dried out or something?
Matt93SE
May 24, 2019 02:58 PM
Jeffesernia11
Aug 23, 2015 06:09 PM
maxocar
Aug 21, 2015 12:57 AM
soon2ownmax
Aug 13, 2015 02:19 PM
laparka66
Aug 6, 2015 09:36 AM
