What parts have you replaced due to excessive rust?
Old Sep 28, 2007 | 06:15 PM
Nopike's Avatar
Because 4th gen are getting older rust appears to be an issue for many of us, unless you are in a warm climate. I recently had the lower radiator core support replaced on my 98 SE due to excessive rust (it was almost totally gone). I am also concerned about excessive rust on the control arms and some of the rear suspension. What parts have you replaced due to excessive rust?
Old Sep 28, 2007 | 06:18 PM
KRRZ350's Avatar
I've done core supports on mine, a freinds, and another .org members car. As for the control arms though, they aren't thin sheet metal like the core support, it would have to be BAD to warrant replacement.
Old Sep 28, 2007 | 06:33 PM
Nopike's Avatar
You did the core support yourself, was it a lot of work? Difficult? How long did it take? I paid $700 to have mine replaced, it seemed like way too much work
Old Sep 28, 2007 | 07:13 PM
MadMaxSE-L's Avatar
Doggah Bite...
My 97 SE came from Long Island, NY - I am in Florida. My core support is rusted as well, that will probably be the next things I have to change(atleast until I go w/ the 3.5 )
It looks difficult, but I don't think it will be that hard.
Old Sep 28, 2007 | 07:27 PM
matty's Avatar
Thats probably the only part youll need to worry about rusting through.
-matt
NmexMAX's Avatar
dot dot dot ...
None whatsoever.
Old Sep 28, 2007 | 07:33 PM
dgeesaman's Avatar
Maintenance Monster
My core support is getting pretty ragged (174k), and my exhaust is just about falling apart but no leaks. So I'll probably change all of them in the near future.
Dave
Old Sep 28, 2007 | 07:36 PM
Nissan 6's Avatar
muffler
Old Sep 28, 2007 | 07:39 PM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by Nissan 6
muffler
Damnit, you got me on that one Yes, my muffler went to muffler heaven due to rust as well.
Old Sep 28, 2007 | 07:43 PM
mtrai760's Avatar
'Trynna' is not a word
My car originally started life in Utah = rust city. Just replaced my core support, several dozen bolts, cleaned a bunch of rust off of various surfaces. I hate rust.
Old Sep 28, 2007 | 07:55 PM
19Maximus98's Avatar
My muffle died, and the light bracket for the rear license plate. I have scraped and coated every part on the underside of my car with
http://www.bull-frog.com/products/
Hopefully this will prevent more rust from forming. Once this stuff dried I applied a coat of spray-on Rubberized Undercoating from Slep Boys. That should do the trick.
FYI...The NorthEast = Rust Central. My car is from NY, tons of rust.
Old Sep 28, 2007 | 09:07 PM
nsnrider's Avatar
that sounds about right if you have a body shop replace the whole radiator support. But if you want a quick cheap fix, just replace the buttom portion of the support. not hard to do
Old Sep 28, 2007 | 09:20 PM
huyqvu's Avatar
rust ate away the pipe behind the resonator. went to check it and the whole thing fell out and broke off at the muffler too. had the whole piping and muffler replaced. rear wheel wells my fault. wheels were a bit wide at 32offset on 18x8 and thats starting to show rust.
Old Sep 29, 2007 | 12:18 AM
KRRZ350's Avatar
Shortly before I replaced mine due to the horrible rot, I had the brand new nissan lower already and I ended up crashing the car bad and damaged the upper as well, I ended up having a junkyard cut an upper out of the car and used the brand new nissan lower, but anyways...... Replacing just the lower is in no way a quick cheap fix, it is the proper way.
But I will agree that it's not hard to do, at least it's not THAT hard to do anyways, the most difficult part is removing the old one, ie drilling all the pinch welds out and what not is a pita, but than getting it to break free involves chiseling and banging and swearing at it and what not. But anyways, the last one I did I was able to do in one day, I didn't get started until around 11:00am and I took several breaks and it was done around 6:30pm.
But anyways, I think the main reason people are scared of this job (asides from the welding which isn't that difficult, plus the bolts do most of the work anyways) But I think most people are scared and let body shops handle it because they think there are alignments and measurements and what not that have to be done perfect, it's not like that at all, once you have the old one off the new one sorta fits into place perfect, you just need to put two visegrips on each side to bring it in as tight as possible before you tighten the three bolts/tow hook on each side. Also, tip: there is no need to remove the headlights, a/c condenser, radiator, etc.
Old Sep 29, 2007 | 06:41 AM
lewdtenant's Avatar
rear license plate light brackets.
Old Sep 29, 2007 | 10:11 AM
MadMaxSE-L's Avatar
Doggah Bite...
Forgot, my stock muffler is about gone too. The outer shell is rusted through...
Old Oct 11, 2007 | 09:25 PM
CanadaMaxima03's Avatar
Has anyone replaced an oil pan?
I took mine 03 Maxima in for its 60k service, and it was rusted right through...
59,2000km
Seems fishy.... 4 years old, low KM...
Old Oct 11, 2007 | 11:18 PM
KRRZ350's Avatar
Yeah that is SOOOOOO fishy
Old Oct 12, 2007 | 06:00 AM
Kof's Avatar
Kof
Im on Long Island in NY. The whole undercarriage is rusted. Im trying to just replace the whole car
Old Oct 12, 2007 | 06:11 AM
ROCKART's Avatar
wants an I35
i never really had a problem with rust on my first max. but then again the car was so beat up maybe i just didnt care...
i had a 93 Maxima SE that i got at 138k. it was a north carolina car (they do have "rough" winters there, as well as tons of salt on the roads due to ice cover)
i then took it back to NY, CT and Rhode Island for about 3 years. then i took it to VERMONT! for 2 or 3 more years. i NEVER had a problem becuase of the cold/snow/salt. i beat the crap outta this thing. and after 5 years the only thing i ever did was my own oil changes and one time i replaced the rotors/pads. it was bulletproof
granted i never bothered to look at the undercarrage (i was a junkie - the car was the least of my concerns), but i think most vehicles are designed to stand up to that kind of abuse.
now if you live by the ocean, that is a much different case.
Old Oct 23, 2007 | 07:17 AM
Alde's Avatar
My 96 Maxima is rusting all over - especially around the tire wells and the bottom portion of the exterior body. I live in Canada and the salt from winter is eating my car. The rust is like cancer and is quickly spreading.
I went to a body shop to get a quote and it was ridiculously expensive. What are my options? Is there a cheaper alternative?
Old Nov 15, 2007 | 02:58 PM
maverick1223's Avatar
Lil' bit more than Newbie
Alde I have the same question as you, I'm in Boston and travel to Vermont all the time. My poor car needs work but I am low on funds especially after having to replace alternator and brakes.....any suggestions for cleaning/rust proofing? OR any DIY things?
Old Nov 15, 2007 | 10:13 PM
headloss's Avatar
Should be in bed...
Catback and most of the supports for the exhaust piping to rust. I started out in PA and am now in WA; every mechanic that has seen my car out here has stated that it's the worst they've seen in a while rust-wise.
Old Nov 16, 2007 | 03:42 AM
showdown's Avatar
Because I Can
my oil pan needs to be replacec cuz its rusted out
Old Nov 16, 2007 | 03:51 AM
flynlr's Avatar
95 max was in cali for 5 years and utah ever since I see rust on that brace under the engine but thats it. so many scrapes due to crappy roads.
Old Nov 16, 2007 | 06:32 AM
lillefty006's Avatar
poppaburgundy
i just replaced my core support because it was basically rusted through....525 for mine
Old Nov 17, 2007 | 06:17 AM
maxima_million's Avatar
With 135k, I'm looking to replace my entire exhaust today. A buddy is going to help me since I don't know squat about the exhaust. I'll post what I replaced....
I also have to replace my ac compressor. Turns out when I replaced the belts, I tightened them too much and now the car is loud at idle. When I removed the belt, the sound dissapeared. There goes another $500+, but at least I'm smarter than before I did the job!
Education is expensive, but ignorance is more!
Old Nov 17, 2007 | 09:36 AM
Peebs187's Avatar
I live in MN and have had great success with POR-15 rust coating. Very simple to use and lasts for many years. Core support can still be saved, thats next. Thankfully my car has a well done undercoating so my rust is minor. My fuel lines seem really corroded, they flake off if you scratch them. I am going to coat those with POR-15 also.
Old Nov 17, 2007 | 12:13 PM
Aeiou's Avatar
Ha ha, yeah, I've got that problem. Went to change one of the bulbs and it just split in half. Ziptied the working bulb for now, but need to get a new bracket...
Old Nov 17, 2007 | 01:14 PM
lewdtenant's Avatar
http://forums.nycmaximas.org/showthread.php?t=27456
To avoid dealing with that rust again, here is an easy mod you might like.
Old Nov 17, 2007 | 03:02 PM
vqmaxman's Avatar
Northeast rust is the worse and when, you drive in the snow and the salt and slush your car is going to rust faster than a blood clot reaching your heart for a attack. I have rust on the rear susupension beam and the exhaust,front suspension and the fuel lines near the tank. I will have to replace my exhaust soon. I have to keep on spraying the wd-40 it helps minimize the rust and some pb blaster. My core support is on it's way out.
Old Nov 17, 2007 | 03:24 PM
I'm also in the NorthEast and I'm terrified to see what everything looks like underneath.....yikes....no one is getting Xmas presents this year, I have to give all my present money to the Max. But she deserves it prob the most lol
Old Nov 18, 2007 | 04:23 PM
Peebs187's Avatar
Not the best time of year for this, but a rust inhibiting chassis paint works really well, especially if you put an underbody coating over it. You wont have to do it again.
Old Nov 27, 2007 | 09:44 AM
emoore924's Avatar
I suddenly have rust RIGHT THROUGH the lower edge of the LF fender, on that small strip just ahead of the wheel well just below the 1" crease on the fender. I keep the car pristine, wash the wheel wells each time the car is washed, and this came up out of nowhere from clean paint to rusty HOLE in about three months! I wonder if the battery tray drain exits near this location and some acid got on there or something.
Old Nov 28, 2007 | 03:36 PM
SuperChris's Avatar
Infiniti 35 Double G's
muffler
...more due to the mileage (268,000) than old age.
Old Dec 1, 2007 | 08:04 AM
scooby68's Avatar
My 97 is in need of lower rad support also. Damn shame, the rest is just normal rust levels for 10 years old. Wish I would have known the car was gonna last this long, I could have re-painted the underside!
Old Dec 1, 2007 | 11:41 AM
Pimpmobile's Avatar
core support replaced at 280000km
Old Dec 1, 2007 | 02:50 PM
Shift_it's Avatar
Maxed Out
I have rust creeping from underneath the rubber stripping on the roof just above the windshield. How should I go about preventing it from spreading? OH and Rubberized Undercoating is GREAT
Old Dec 1, 2007 | 03:40 PM
Maxgig's Avatar
Peel back the rubber strip sand off the rust then cover the bare metal with some varnish and finish it off with some body colored touch up paint. When it gets warmer out have it looked at by a body shop, in the meantime you can keep doing that until you can afford to get it done by a shop.
Old Dec 1, 2007 | 06:52 PM
kzoosho's Avatar
I have a 4th gen with the lower support going also. It really sucks man.
