illumia numbers for the rear...
Old Sep 30, 2007 | 08:30 AM
TurTLe*'s Avatar
I think this is the right place rather then the suspension section.
So i got a used set of illumia's i installed everything and go to set everything. Obviously illumia's are 5 way adjustables. I did the fronts peice of cake. I go to the rear and um... i can adjust them but i dont see a number bracket of any sort on either one of them. I cant tell what setting number is what for the rears. The fronts are dead obvious but the rears dont have any....
maybe mines came off or something of that nature. can someone take a picture of what the rear is suppose to look like...
http://www.hitachi-hap-la.com/Tokico...illumina_1.gif
this is what i see in the front. but the only red i have in the rear is the slit to adjust. i dont have the 1-5 sticker/ plate of w/e is there.
Old Sep 30, 2007 | 10:05 AM
EnervinE's Avatar
i has college
The rears should have come with little caps you put on the top, that have the numbers on them.
Old Sep 30, 2007 | 02:59 PM
TurTLe*'s Avatar
hm.. so they are removable? i'm asking so then i can just order the caps from tokico and be good.
Old Sep 30, 2007 | 11:39 PM
maxgtr2000's Avatar
KH3 by popular demand
They are removable.
Old Oct 1, 2007 | 09:23 PM
konak85's Avatar
yeah those caps are supposed to come off after adjustment, they fit the rears also. Put them in the glove box after adjustment and you're good. My rears have numbers on them even without the caps, get a flash light and look at it good.
Old Oct 2, 2007 | 08:04 AM
TurTLe*'s Avatar
interesting.. i took a quick look cause i thought it was engraved or on the flat side of the threads and nothing. i'll just swap the front to the back then store them...
so i tried it....
caps are removeable but not interchangeable. there is a slit for the fronts but no slit for the back. There is a flat spot at 5 and i aligned it with the flat on the rear. i assume that would be the locking point for the rears but i dont know. either way i aleast not my settings were even.
jmlee44
Oct 2, 2022 02:13 PM
maxinout93
Oct 31, 2015 02:04 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
King_Ten_Ahead
Sep 27, 2015 02:24 PM
