Break pad replacement issues
Old Oct 2, 2007 | 09:54 PM
tinuc's Avatar
Ok so I recently changed my breaks. Front breaks was no problem. I ran into some trouble with the rears.
The cylinder in the caliper would not push back in the! I tried but it was very hard and didn't want to put more tension on the break line so I just put the old break pads back in and called it a day.
Is there a pressure valve that I forgot to take out or something? I mean the hand break is released so I figured that would do the job.
Does this mean I need to replace the caliper?
Old Oct 2, 2007 | 10:42 PM
freshv6power's Avatar
I think you have to twist them as you push them in. There is supposed to be a tool that you can buy to make it easier.
Edit: This thread should have the info you need
Last edited by freshv6power; Oct 2, 2007 at 10:48 PM. Reason: added link to another thread
Old Oct 9, 2007 | 07:43 PM
nafddur's Avatar
You definitely have to turn the piston as you push it into the caliper. There are several simple, readily available tools to do this. I bought one (called a disc brake piston tool) marketed by CTA manufacturing corp, Carlstadt, NJ - for $10 (several years ago). The one I got was CTA part #1455. It works like a charm - I've used it on several different cars.
Old Nov 15, 2007 | 06:45 PM
tinuc's Avatar
Thanks guys, it worked!
Old Nov 15, 2007 | 08:16 PM
MaximaPimpin's Avatar
Yeah whatever you do, do not get that tool from Pep Boys because when i did mine and bought their tool it was completely worthless. All it did was turn and not push it in, it ended up breaking the same day i bought it and they wouldn't give me a refund...
Old Nov 15, 2007 | 09:32 PM
SVI30's Avatar
The dimples in the piston has to line up with the nibs in the pad after you turn it in.
rbuswell
Nov 17, 2016 04:54 AM
homeyclaus
Sep 3, 2015 06:15 PM
Jeffesernia11
Aug 23, 2015 06:09 PM
kirkhilles
Aug 8, 2015 10:53 AM
RealityCheck
Aug 5, 2015 06:18 AM
