who knows how ro adjust the rpm my is at .5 on idle
If your car is at .5 RPM there is something seriously wrong with it, and I dont think it would be on at that point either. I think you are refering to 500RPM and trying to get it to 1000RPM(which is a bit high for idle)
U know the crazy thing is that when i try to adjust the idle with the TPS i can't level it out to 1000 rpm it would be either more then 1000 or at 500 ? u guys know what's up with my car? and by the way does any know how to adjust it the other way i guess there is a real way to adjust please tell me with detail locations and all thanks !
500rpm
I am actually having the same problem, except sometimes the car just stalls, when the car is in motino it runs fine. I changed the spark plugs and bought fuel injecter cleaner and it still low on idle. I do here a hissing noise from underneath the car, if i were to have an air leak, how could I find it and how could I fix it.
Adjusting idle speed can be found here: http://web2.airmail.net/scutchen/max_faq/
Which can be found here: http://forums.maxima.org/showthread.php?threadid=39141
Which you should have read before posting.
RPMs:
700 +/- 50 (automatic transmission, in Neutral)
625 +/- 50 (5-speed)
I thought somebody said something about not messing with the idle adjuster earlier in a DBM post. I can't remember who it was and couldn't find it in search but if something is making your rpm go that low, chances are changing the idle adjustment is a "quick fix". You should probably find out what's causing it and fix that instead.
^- Maitenence, under adjusting 4th gen idle speed.
Might want to check you throtle and idle cables if they are loose they will jack up your idle adjustment and also if you tighten them both your throtle reponce with be much better im talking a whole lot better.
Papasmurf
Bruce Rice
Papasmurf
Bruce Rice
Check your vacuum hoses for any type of leaks or "Falsse Air". False Air is when your MAF is getting a leak somewhere and it will cause it to make bad readings controlling where your car is idling at. For example if it feels it is too high/low then it will change your idle accordingly maybe it finds it high in your case and lowers the idle. Just athought.
SuDZ
SuDZ
idle issues
Hey for about a month now my stupid car was shaking at 550rpm when idleing, well after chagin sprk plugs, and adding all those stupid fuel injecter fluiding to my tank nothing happened, then someone suggested that I spray throttlebody fluid in my throttle body because some crap my be in the throttle. and it worked, now I am at 770rpm, no shakes, thanks to whoever suggested that for me. its a pain in the *** though, i had to take the filter box out and the thing with the senser but it was worth it.
tarun900
19
Dec 20, 2021 06:57 PM
Unclejunebug
Apr 2, 2016 05:42 AM
