Possible oil change problem
Old Oct 7, 2007 | 12:10 AM
wootwoot's Avatar
I changed the oil tonight in my maxima. I used a nissan filter and some oil amsoil that I had. I ran out of amsoil and had some generic fluid laying around so I used that to top it off. The problem I ran into was that the generic oil bottle looked the same as this generic ATF fluid bottle. I grabbed the ATF fluid bottle and accidentally used that and poured a gulp of ATF fluid into the oil. Will this break the oil down or cause other problems?
Old Oct 7, 2007 | 12:16 AM
GStrength's Avatar
LOL your a slow ***. If you haven't already ran your engine, pour it out. Run another quart or two of cheap oil and try to run it out. Hehehehe.
Old Oct 7, 2007 | 12:21 AM
Define "gulp".. a few ounces or???
Ask yourself this...is your engine worth the cost of 5 new quarts of oil?? And, why are you mixing oils?? It seems you wanted to put a very good quality oil in your car, then you attempt to add generic oil because you ran out? That doesn't make sense to me.
I'd drain it, and let it drip for an hour or so to try and get every last drop out, then refill it with fresh motor oil (all the same brand too).
Old Oct 7, 2007 | 12:29 AM
wootwoot's Avatar
As soon as it started to come out I saw it was not oil. So maybe an ounce or two.
Old Oct 7, 2007 | 12:30 AM
wootwoot's Avatar
I thought I had 5 quarts but one of the bottles was empty. I ended up putting in 4 quarts of good stuff and 1/2 or the cheap stuff.
Old Oct 7, 2007 | 01:05 AM
GStrength's Avatar
Yea what i meant was pour it out. Keep the drain plug removed and run two quarts of cheap oil and just let it drain out.
Old Oct 7, 2007 | 01:18 AM
johnnyboy's Avatar
just do a engine flush to make sure its cleaned out fully
Old Oct 7, 2007 | 07:03 AM
nitromax's Avatar
over the years I have done that a time or two with no ill effect on the engine. ride in peace 'til the next oil change.
Old Oct 7, 2007 | 07:29 AM
tvis's Avatar
I always run tranny fluid in my engine, and motor oil in my tranny
Old Oct 7, 2007 | 07:57 AM
mansurxk's Avatar
it's detergent properties act as an engine flush already. some people add the trans fluid to remove buildup in the engine.
just drain a little a little fluid and refill with some motor oil and handle it the next oil change.
Old Oct 7, 2007 | 08:31 AM
67whitegoat's Avatar
mansurxk and nitromax are absolutely correct. It will not hurt anything. Run until your next oil change. And be more careful next time.
You can mix engine oils, ( i.e. weight, brand, synthetic and standard oil ) but why would you. Especially expensive oil like Amsoil. Mixing wont hurt, but it certainly won't help.
Note: I would personally never mix oils.
Old Oct 7, 2007 | 08:35 AM
dgeesaman's Avatar
Maintenance Monster
Don't worry about it.
Old Oct 7, 2007 | 11:33 AM
Snypa's Avatar
just drain that mawfugga now.....drain it drain drain it.to the last drip.then fill back up with fresh oil.
Old Oct 7, 2007 | 03:20 PM
Ah... I see.
Yeah, for an ounce or two, you're more than likely ok.
boomerbrian
Oct 31, 2018 10:25 AM
kjlouis
Oct 3, 2015 05:29 AM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
coasterswim
Sep 2, 2015 07:43 AM
