Window regulator replacement DIY anywhere ?!?
Old Oct 8, 2007 | 12:41 PM
flthere's Avatar
98 Infiniti I30 ... problem with power window on the front passenger side ... I can hear the motor spinning but the window rolled down couple inches and will not go up or down using the power switches ... I manually rolled the glass up but it won't stay like that if I go over bumpy roads (everywhere here in north chicagoland, even on highways) ..
anyways, i presume since the motor is spinning, may be it's the window regulator problem ... Adv Auto has the window regulator for 40 bux and I want to see if I can install myself ... did anyone do it themselves or can you plz point me to a DIY site just so I know what I'm going to do/see once I open the door panel ?!? thanks ...
Old Oct 8, 2007 | 12:47 PM
black_maxed95's Avatar
buy a haynes. i used it when i took my door apart and took off my window motor and regulator. its not hard to do yourself
Matt93SE
May 24, 2019 02:58 PM
Cotozic
Jun 28, 2017 08:01 PM
vingodine
45
May 21, 2016 12:46 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
Superbform
Aug 11, 2015 08:10 PM
