alignment question??
Old Oct 20, 2001 | 08:53 AM
paco's Avatar
is it true that the rears can not realy be aligned ....so its realy a waste 2 get a 4 wheel alignment?
Old Oct 20, 2001 | 08:56 AM
Sonic's Avatar
Yes, they cannot be aligned, but you should still see if they are within spec. It decreases tire wear if they are.
Old Oct 20, 2001 | 08:58 AM
araffio's Avatar
no this is definitely not true. i just had a 4 wheel alignment done and the guy told me my front end was way out of whack. He said it took two guys to straighten it because it was bent so far (had a small accident a year ago). Anyway, I went through a set of tires in a year b/c the front was so bent. Whereever you heard that only the back gets done is wrong.
Old Oct 20, 2001 | 09:00 AM
sinewave's Avatar
It's true, there are no adjustments in the rear. About the only use of a 4-wheel alignment is to find out what the caster and camber of the rear wheels are at, but I don't think your average front-end shop will be able to change them. This may be useful info if you plan on autocrossing or if the car has been wrecked.
Old Oct 20, 2001 | 09:45 AM
Toolrocks's Avatar
Alignment shops use the rear wheels to determine the 'thrust angle'. While it is true that nothing can be adjusted in the rear it is still used for a point of reference. Through a 4 wheel alignment I was unfortuantely able to determine that I have a slightly bent rear axle. Yeah This bend affects my thrust angle, so my steering wheel will always be a little off center. So far I'm not eating tires up, so I'll just monitor it. $$$$$$$$$$
Old Oct 20, 2001 | 10:43 AM
buss95max's Avatar
u align the front wheels.
make sure to have the same size tires all around. i went yesterday with steelies in the front, cuz my alignment was eating away my kumhos. and i couldnt get my alignment becuz i had 17s in the rear, and 15s in the front
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
doctorpullit
Mar 29, 2016 11:08 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Socalstillen
Sep 26, 2015 12:01 PM
