suspension help can't get bolts into knuckle!!
Old Oct 12, 2007 | 08:38 PM
  #41
KRRZ350's Avatar
Yes but since you have replacement axles you probably got ones for an abs car since they will also work on non abs models. It's normally to see those teeth.
I think it's safe to say that when your inner joint popped apart and then you somehow got it back in the metal retaining clip inside got damaged. I'd pick up a new CV, there is probably a warranty on that one.
Old Oct 12, 2007 | 08:40 PM
  #42
Nopike's Avatar
I doubt you damaged anything, I screwed around in there pretty good also, it's not that easy. Again make sure the parts you are installing are the correct size. Is it possible that you got the wrong parts? Does the other side seem OK?
Old Oct 12, 2007 | 08:42 PM
  #43
Nopike's Avatar
KRRZ350 that makes sense. Good possiblity.
Old Oct 12, 2007 | 08:57 PM
  #44
achebee4you's Avatar
you think i can drive it back to the shop that installed it? it is about 20 miles south of me and i'd have to take the highway there i just don't want to wreck "worse case scenario" But why would it make a loud metal crapping noise only when i turn would the inner cv joint make noise in a straight line as well?
Old Oct 12, 2007 | 09:01 PM
  #45
Nopike's Avatar
Probably when you are driving straight the joint is seated properly in the trans, but when you turn it pulls on the CV joint and it is not properly seated?
Old Oct 12, 2007 | 09:19 PM
  #46
that sucks if thats the case i hope they warranty it because they might see that i changed my suspension bc i scuffed up the axle shaft trying to get the strut mounted
Old Oct 12, 2007 | 09:56 PM
  #47
the noise is so loud it sounds like metal dragging on the ground but i'm not dragging anything could noise be created from the inner cv joint with all that grease and boot around it?
Old Oct 13, 2007 | 06:34 AM
  #48
Nopike's Avatar
How about this, turn the steering wheel in the same position where you get the noise while driving. Jack the car up, put it in netural and turn the wheel by hand. See if you can determine where the noise comes from. Try this with the wheel on and off? With this noise being so pronounced you should be able to recreate it with the car on jackstands. It may not make the noise with no load on the suspension but worth a try.
Old Oct 13, 2007 | 03:32 PM
  #49
KRRZ350's Avatar
^^ Excellent advice, allthough it probably is that axle that seperated, that metal clip gets fuxord when that happens, but just to be on the safe side do that, and yeah definitly bring it back to the place and see what they will do, eeven if they won't waranty it theres a good chance that wherever they got that axle from has a warranty on it so at least you won't be out the $100 or whatever.
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
