Settings of Illumina Shocks
Old Oct 9, 2007 | 02:24 PM
MaximaPimpin's Avatar
I'm installing my illuminas tomorrow and i was wondering what setting everyone was using for the front and back of the car. Should I go stiffer at the front and softer in the back, or just keep it both soft?
Old Oct 9, 2007 | 02:36 PM
emoore924's Avatar
I use 1 at both ends but I'm an old fart with a 75mile/day commute and I don't like getting my teeth knocked out. To me, the illuminas/springs seem to be rather oversprung anyway.
Old Oct 9, 2007 | 02:59 PM
Morpheus2010's Avatar
1 all the way around. I have se manual springs in the front and gle auto springs in the back. Mine feels great. trust me i had h&R springs it does not feel good. Unless your control arms, tie rods and end links are new then have fun.
Old Oct 9, 2007 | 07:18 PM
Heh thanks guys, yeah I was thinking of doing 1 all the way around. But maybe I will try to do 2 in front and 1 at the back just to get the front a little tighter.
Old Oct 9, 2007 | 08:23 PM
EnervinE's Avatar
i has college
Uhh...wtf? I run 4 front and back as a daily driver. It's not that stiff, even with a drop.
Old Oct 9, 2007 | 08:25 PM
Yeah i guess it depends on quite a few things, like rim size, tires, condition of suspension. Just going to play around until i get a perfect mixture.
Old Oct 9, 2007 | 08:30 PM
EnervinE's Avatar
i has college
I run 27 pound 18" Muranos and rubberbands at about 42 psi.
Old Oct 9, 2007 | 08:55 PM
0.o, wow man. You must not be sensitive to all the road bumbs then or something heh heh. Going to see how it turns out tomorrow morning when I put them on.
Old Oct 12, 2007 | 09:38 PM
NetFurie's Avatar
3/2 here on tokico lowering springs with stock 16" wheels. I messed around with settings over the last 3 years and this seems to have the best of both worlds.
Old Oct 12, 2007 | 11:08 PM
Interesting, i'm running them on 1s right now. They are really soft, not used to it because i drove around on the SE springs which are much stiffer but its not a bad thing. I might give 3/2 a try.
Old Oct 13, 2007 | 02:23 PM
achebee4you's Avatar
more ppl seem to prefer softer setting for the rear? what would be the reason behind this understeer?
Old Oct 13, 2007 | 03:50 PM
Fast1one's Avatar
Same here, its not stiff AT ALL, some people can't take it I guess...
Now an s13 on full coilovers, thats stiff...
Old Oct 14, 2007 | 12:53 PM
max95q's Avatar
I had mine on 4 front 3 back but then I changed it to 5 front 4 back. Now I have it on 5 all around. Its a fun drive
Old Oct 14, 2007 | 04:51 PM
ThurzNite's Avatar
5/5. I'd experiment w/other settings, but too lazy to pull the trunk liner back. PITA and I'd say dumb design on Tok's part, but whatevers.
Jae
Old Oct 14, 2007 | 05:01 PM
Gismo-T's Avatar
B!tch We Got a Problem
... I used to have mine set at 3F & 4R, the front seemed to soft...so I switched to 4F...rides gr8 ...I'm also on Progress springs...FTW
Old Oct 14, 2007 | 05:12 PM
EnervinE's Avatar
i has college
Lol that's exactly what I did.
Old Oct 14, 2007 | 08:59 PM
Yeah one does definently feel too soft, im used to the stiff suspension of SEs so i might bump it up to 3s all around and 4s in a week to see a different.
Old Oct 15, 2007 | 02:03 PM
max95q's Avatar
I think some of the settings also have something to do with the springs as well. If you are running stiffer aftermarket springs than another then the settings could differ. I bought the whole Tokico package with the tokico springs. Others may have springs with different ratings so you could end up pretty much testing the settings yourself to see how you like it with your set up. I also have a 5th gen FSTB and an ADDCO RSB. Tires I think have something to do with them as well because I run 17x7's on 235/45 tires and it feels a little softer than when running my factory rims and tires.When I ran the 4f/3r on the factory tires and rims the 4f/3r setting felt stiffer.
Old Oct 15, 2007 | 04:18 PM
Dooley's Avatar
3F, 4R, running H&R's on 17's with 45 series tires.
Old Oct 15, 2007 | 06:23 PM
Nightkid08's Avatar
3F/3R with 15" wheels and eibach drop...I like it.
Old Oct 15, 2007 | 06:44 PM
Yeah i got the whole tokico package. I agree i think the springs play a major role in the settings.
Old Oct 16, 2007 | 11:02 AM
vilmaxima's Avatar
i got'em on 3 all the way around with eibach pro-kit and 17's
Old Oct 16, 2007 | 02:55 PM
adithius's Avatar
I'm running 2/2 stock wheels 16 & stock springs. Still seems a little jarring for my tastes. I'm going to try doing 1/1.
Old Oct 17, 2007 | 10:03 AM
MrDicks95SE's Avatar
Offset Is Everything.
4fr/4rr on 450lb/in-FR 350lb/in-RR springs.
Old Oct 17, 2007 | 02:06 PM
Awesome car man.
Old Oct 18, 2007 | 08:34 PM
mowgli29's Avatar
Horizontally opposed.
I've got Eibachs on mine. For a while I had been running 4F 5R. I thought that might help counter understeer a tiny bit. I doubt running the front softet actually helped counter understeer, I bumped it to 5F 5R now and I love it. Stiff, but not bad if you drive on decent roads.
Old Oct 29, 2007 | 09:13 AM
kartiste's Avatar
One thing possibly to take into account: Tuning to the humps on elevated freeways. I had to experiment to find a sweet spot that damped out the bounciness. And BTW, that set of Illuminas, plus a FSTB, transformed the car. It really handles great - good turn in, good stickem, not much body roll. The only thing I'm still unhappy with is this subtle yaw oscillation in long high speed turns. Probably it's bump steer associated with the twist beam geometry, but I can't figure out why it would oscillate....
Kartiste
"Carry On, & Dread Nought"
Old Oct 29, 2007 | 12:56 PM
ThurzNite's Avatar
I took a 400mile trip this weekend and had them set at 1/5. When I stopped at my destination, the fronts looked lower than when I had it at 5/5. I will measure later.
Jae
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
