L E D interior W/pix---->
Old Oct 12, 2007 | 10:43 AM
  #41
Punky's Avatar
do you find it uncomfortable at night? looks crazy bright
Old Oct 12, 2007 | 03:04 PM
  #42
dblock1's Avatar
97' SE 5spd.
Originally Posted by chillin014
can you even have hot spots in the window switches?
the rear switches were as easy as the fronts to me...same thing as the passenger side.. and to the OP yeah you didnt need the resistor for the window switches as someone else said.
I never said you need them. I said that I tried it with them first and it didnt hurt so I didnt stop using them.
No they are not too bright i put them on max brightness for the pictures. I use the room dimmer to lower them at night. They almost turn off so they are always adjustable to your preferance.
Old Oct 12, 2007 | 03:15 PM
  #43
dblock1's Avatar
97' SE 5spd.
Originally Posted by shissqbob
just to throw it out there I used a belt sander and sanded the led flat to about 1mm above the silicon inside the led. I placed these in the window switches and no hot spots could be seen. I know it'd take a while to hand sand it but it's worth it
also, i just wrecked the flat led that's in the rear window switches so that it didn't glow green or turn on at all. Did you do these? I found it'd be close to impossible without a solder sucker.
Ill post pictures later tonight when its dark but yes i did do the rear window switches. I droped some solder here and there and just sucked it up with the gun somehow, you could also try cutting with small wire cutters or chip it off. The secon set of pictures up above is actually from the rear switches here r some more
Old Oct 12, 2007 | 03:16 PM
  #44
wariow's Avatar
looks good, pics tell a 1000 words
Old Oct 12, 2007 | 05:52 PM
  #45
shissqbob's Avatar
idk, i guess my 98 started the trend. In the rear window switch, nissan put in a flat led looking something like this: http://en.goodlamp.com/upload/flatpiranha.jpg
they did this because some type of black chip is on the other side, which would cause a problem if a regular led was placed in there.
this, in turn, is pretty annoying. it is soldered at 4 different points which are within 2 mm of each other...a brain surgeon would have trouble doing it.
Old Oct 12, 2007 | 06:59 PM
  #46
Snypa's Avatar
bright and looking good,nice job
Old Oct 16, 2007 | 12:43 PM
  #47
t65k3's Avatar
Still Learning
I noticed that your auto climate control was not lit....
Do you happen to have a brief writeup for the CD player?
Old Oct 16, 2007 | 03:19 PM
  #48
ZachsMax's Avatar
Ridin' Spinnaz
I just swapped mine to red.. what I did for the back two was remove the board, go out to the car, and with the small green square LED lit up, I tried my red LED on the different leads connected to the green LED until I found the combination that lit up my red LED. I then soldered it (with my resister, of course -- though I learned it might not be necessary on window switches) and blacked out the green LED with a permanent marker. For some reason, though, after doing this neither of the back ones light up.. made sense to me at the time
Oh well, I don't really care about the back ones lighting up anyways. I never ride back there lol
Old Oct 16, 2007 | 03:30 PM
  #49
J-hop's Avatar
wariow i was just doing some reading and saw that you were sourcing your LEDs from a guy on ebay. Have you tried http://www.besthongkong.com ?? I order all my LEDs from them, last time i ordered i paid $12 canadian for 100 blue LEDs including shipping. You get better deals with the more LEDs you buy and you can also select what range of illumination you want ( ie 10 degrees, 20 degrees etc). The guy you buy from may even get them from the same source as these guys
Old Oct 16, 2007 | 05:47 PM
  #50
5StarMaxima's Avatar
must be bright as hell in there at night. Looks good though
Old Oct 16, 2007 | 06:29 PM
  #51
KillaJakez's Avatar
I did 5mm blue leds for my auto climate control. It is way too dim. I sanded them down as well. Should I just go with leds that are higher rated mcd? I think mine are 3600 or so.
The two images are both taken by my cell phone under different light conditions, thats why they look so different.
Old Oct 16, 2007 | 08:09 PM
  #52
dblock1's Avatar
97' SE 5spd.
if you dont sand them they will shine through brighter and you can use your interior dimmer to adjust how bright you want it!!! Theonlyplace I would say to sand is the guages and the indicator light for the rear defoger b/c it doesnt hsve a stock defuser/shield and shines rightin you face ...
Old Oct 16, 2007 | 08:52 PM
  #53
Powerman5115's Avatar
How did you do the door lights? I tried putting in one LED but it blew. Did you buy the ones on ebay? I like the blue. I have light blue/white in my window switches.
Old Oct 16, 2007 | 11:13 PM
  #54
t65k3's Avatar
Still Learning
I used ~15000mcd white 5mm leds.
I made the dome of each led flat by sanding, trying to reduce the hot spots, which helped, in a way, for leds not to be too bright.
Old Oct 17, 2007 | 02:10 AM
  #55
johnnyboy's Avatar
Cool man i will try it out soon
Old Oct 17, 2007 | 07:09 AM
  #56
wariow's Avatar
sig is old. Haven't updated for over a year now but if besthongkong.com is good, i'll try them out
Old Oct 17, 2007 | 08:55 AM
  #57
KillaJakez's Avatar
huh? I used the auto climate blue led mod in the interior sticky
http://www.z3d.com/maxima/blueclimate.html
It taps into the 12V. There is another way to do it?
Old Oct 17, 2007 | 03:24 PM
  #58
dblock1's Avatar
97' SE 5spd.
My auto climat control doesnt work after 2 days of trying to fix it. I figured you were talking to me and the leds that do work in my car ie: window switches, hazd., rear defog (the photos at the begining of the thread) are dimmable. Sorry
Old Oct 25, 2007 | 11:38 AM
  #59
dblock1's Avatar
97' SE 5spd.
Some more new pics I dont like the diffused look although i did it on the map light and key ring led's (one's NA).
Finished to date:
~FR door
~FL door
~RR door
~RL door
~Courtesy lights
~hazd
~Rear defog
~Ash tray
~Glove box
~key light
~Map light
~Cluster
~Low fuel indicat
DAYTIME
NIGHTTIME
Old Oct 25, 2007 | 11:58 AM
  #60
maxx0831's Avatar
Dblock, How did u manage to do the key light. Ive been lookin, but dont see any stickies for that
Old Oct 25, 2007 | 12:34 PM
  #61
dblock1's Avatar
97' SE 5spd.
You have to disconnect the housing around the steering column to get access to the wires. Pop off the pice that covers the ignition and key lock with your fingernails, use some muscals!! Unscrew the 6 screws holding the part together from underneath, the first pix shows only 4 screws there are 2 more closer to the engen. You might have to remove the bottom dash kick plate to access the front most screws. (look at the second pics). The white cap over the light must be removed, fliped up first, then the clear and white housing slide off the key igition . You have to custom the led and resistor to fit in the white housing but you have some room to play. Make sure that when you close the cap on the white pice it doesnt hit the led. I ended up not using this pice anyway for no reason at all, no extra light will shine through from not using this pice. I have another led on the other side of the clear ring to eaven out the glow but the solder broke and its no longer connected. I need to just get to it, its fairly easy to do as well
THESE 4 SCREWS
POSSIBLY REMOVE THIS KICK PLATE UNDERNEATH THE STEERING COLUMN
REMOVE THE WHITE CAP OVER THE STOCK BULB
SLIDE THE PICES OFF AND UNTANGLE THE WIRE HARNES
Old Oct 25, 2007 | 08:55 PM
  #62
95arcticpearl's Avatar
in a 95-96 cluster the 194 bulb should just be plug and play. I changed the 194 bulbs in mine to just blue coated halogen bulbs from the stock ones and it was a direct fit. I plan on changing everything over to led very shortly though
Old Oct 25, 2007 | 09:01 PM
  #63
maxx0831's Avatar
thanks alot Dblock great pics
Old Oct 25, 2007 | 09:02 PM
  #64
incognito903's Avatar
i used an unsanded inverted LED bulb off ebay that fits in there...#74 or something (bear with me, I am at Annapolis and havent worked on my car since summer 2006 ). I 'lined up' the hollowpoint of the LED with the squarish end of the plastic injection that is the ring with tape.
there isnt really much of a hot spot since the ring has a kind of beveled surface to it.
here is the regular naked bulb with blue sharpie on it...terrible
much better
the same type of LEDs produced some hotspotting in the instruments, however but its not as bad as my camera makes it look. hope this helps
just my $.02
Old Oct 25, 2007 | 09:35 PM
  #65
maxx0831's Avatar
much better
just my $.02
Wow, yeah thats alot sure does help
Old Oct 25, 2007 | 09:37 PM
  #66
maxx0831's Avatar
I mean thanks alot sure does help, perfect timeing too, i just finished installin inverted leds in my cluster and have left overs, so ima give it a try tommrow
Fbana41
Aug 29, 2016 12:18 PM
BobTX10
Oct 7, 2015 08:43 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
GregL65
Sep 7, 2015 10:33 PM
