View Poll Results: A/T ONLY: Do you use your E-Brake when parking?
No
27.00%
Yes
73.00%
Voters: 100. You may not vote on this poll
A/T ONLY: Who uses their E-Brake when parking?
Old Oct 19, 2007 | 06:29 AM
ROCKART's Avatar
wants an I35
so i grew up in New York City, driving my parents Volvo automatic. It is just understood that when you park on the street in Manhattan, you use your Emergency Brake - everyday someone lightly bumps your car trying to weasel in or out of a tight spot.
but then i moved to rural CT, RI, NC, VT and slowly began to use my E-Brake less and less.
now i never use it.....
i got into my buddy's car the other day and started making fun of him because he uses the EBrake with an automatic transmission. he said that its actually better for the cars transmission (because its not resting on a gear) and the brake lines (because it keeps them tight, and doesnt allow slack)
is there any truth to this?
Old Oct 19, 2007 | 06:52 AM
BLACKonBLACK98's Avatar
Former Vendor
e brakes are for driving not parking! jk.
Old Oct 19, 2007 | 07:07 AM
nick_auto96's Avatar
It depends where you park. If you park on a level surface, than it's not needed. If you park on downhill or uphill, then use it. And yes, it's better for transmission when you use it (notice how hard it's to shift from P when you don't use e-brake on a hill) It's just parking brake-use it for what it was designed for. Also, don't use e-brake when the brakes are too hot otherwise you'll just boil you brake fluid and/or wrap the rear rotors
Old Oct 19, 2007 | 07:11 AM
ROCKART's Avatar
wants an I35
yea i was referring to parking on a level surface.
Old Oct 19, 2007 | 09:59 AM
67whitegoat's Avatar
My Maxima is auto and my Chevy truck is auto. I use my e-brake every time, no exceptions.
Old Oct 19, 2007 | 10:00 AM
Iceman420's Avatar
(insert witty one liner)
Old Oct 19, 2007 | 10:05 AM
KillaJakez's Avatar
e brake on any incline. I mean...ANY incline. even if it is barely noticeable. Because if we don't, then you get that hard clunk when you shift out of park, and that cant be good.
Old Oct 19, 2007 | 10:08 AM
XAugusta MoonX's Avatar
This has been debated many times. I'm standard so I have to use mine, but I believe the general consensus is don't use the transmission as a kickstand. Use the e-brake. It's really not that hard to pull back a lever...
Old Oct 19, 2007 | 10:30 AM
Some habits are a good thing.
Old Oct 19, 2007 | 10:51 AM
heynow's Avatar
my e-brake doesn't work
Old Oct 19, 2007 | 10:56 AM
ROCKART's Avatar
wants an I35
any credibility to this brake line myth?
it keeps them taut and thats better than keeping them relaxed?
Old Oct 19, 2007 | 11:15 AM
ChubbieBoi's Avatar
i have a 97 auto and i use my e-brake everywhere i park. i don't like the feeling my e-brake down at park, i don't know why lol
Old Oct 19, 2007 | 11:32 AM
svojs's Avatar
Why an automic Maxima has an e-brake? It won't exist without any purposes.
Use it!
Old Oct 19, 2007 | 12:04 PM
bigpulve+'s Avatar
E brakes are for wussies.....I trust my auto to hold it....
Old Oct 19, 2007 | 01:46 PM
ThurzNite's Avatar
Still waiting for someone to explain how an auto tranny locks the wheels in park....
Jae
Old Oct 19, 2007 | 01:53 PM
bigpulve+'s Avatar
Jae
It doenst "lock" the wheels....what it does it makes makes the wheels rotate in different directions...that is why it can roll forward or backward slightly...
Basically one wheel turns backwards and the other turns forward canceling each other out and keeping the car stationary...
Old Oct 19, 2007 | 01:54 PM
nalc's Avatar
There's something called a 'park pawl', the way it works being that it sticks a little pin through the gear, which prevents the driveshaft from turning. That's why if you put it in park on an incline without using the e-brake, it will roll downhill a few inches until the pawl catches.
I used to have a beater Mazda AT, I used the handbrake lever usually when I parked it, because my dad taught me how to drive and he drives stick, so he always pulls it. That habit rubbed off on me so I always pulled it. Then I went to an Oldsmobile AT, and that had a foot e-brake, so I got into the hang of only really using it on an incline, since it never became instinctive to me. Then once I got my Maxima MT, I have to do it, and if it was a habit before, now it's really a habit. And now if I drive someone's AT car, I always pull it, and sometimes that person forgets to take it off.
Old Oct 19, 2007 | 02:11 PM
iwa2008's Avatar
I use the E-brake, when I dont I notice that the car rolls slightly backwards when shifting out of park.
Old Oct 19, 2007 | 02:47 PM
mowgli29's Avatar
Horizontally opposed.
I used to use my e-brake when I had an auto (still use it with the 5spd).
My question is, how will that "boil your brake fluid"? Maxima e-brake is mechanical, uses a cable, no?
And good luck warping your rear rotors with the e-brake. First of all they don't get as hot as the fronts, second of all the e-brake doesnt put a whole lot of clamping force on the rotors, just enough to keep them in place.
I have parked with my e-brake on IMMEDIATELY after slowing from 120mph. They didn't warp. You'd have to do some serious driving to get them f'ing hot and rip the e-brake pretty hard to warp the rears. IMHO...
Old Oct 19, 2007 | 02:51 PM
andrei3333's Avatar
Always use it, the cable will/may rust and will need replacement if its not used for a season or two right ?, its also a good idea not to rest the tranny in P (think when u let off the brake pedal the car slightly moves and comes to a stop) this is a bad thing to do
Always use the e brake - EXCEPT in the winter in sub zero temperatures when it may freeze
Old Oct 19, 2007 | 04:01 PM
alex_03maxSE's Avatar
I always use my E-brake. Probably because I got into the habit of using it since I used to drive a 5spd.
Old Oct 19, 2007 | 04:17 PM
tvis's Avatar
Every time. No matter if I'm parking on an incline or level ground, my routine is as follows....
Stop and keep foot on brakes
shift to neutral,
pull up e-brake,
let off brakes and let car settle on e-brake,
shift to park.
and FWIW, I do the same thing for my manual trans vehicles.
Old Oct 19, 2007 | 04:50 PM
pmohr's Avatar
No more Maximas...
shift to neutral,
pull up e-brake,
shift to park.
I do the same exact thing, I want the car's weight resting on the locked wheels, not on the parking pawl.
Not how any auto I've ever torn apart works, that includes everything from TH350s to RE4F04As, to 4L60Es, A4LD, A4OD, etc etc.
Close, but not entirely correct. There's a 'gear' on the back of the output shaft (IIRC, I haven't torn apart an RE4F04A in about a year now), and a lever that looks much like the hammer on a sidearm, operated by a mechanical linkage when the shifter is placed into park. The lever slips into the gear, prevents any movement of the axles (obviously there's still some, it's not a press fit).
Best image I can find of it:
Granted, that's a transmission, not a transaxle, but exactly the same thing, just different placement.
Old Oct 19, 2007 | 04:51 PM
wuzzy's Avatar
i use it on an incline
Old Oct 19, 2007 | 05:08 PM
tvis's Avatar
http://www.cowdery.org.uk/images/zf/DSCF2125.JPG
Yup, close enough. I had already been doing my lil routine before I found out about what is actually keeping your car in place when you don't use the e-brake. When I found out that it was just a little lever on a gear thing (park pawl), I was completely sold.
Old Oct 19, 2007 | 05:09 PM
97 joe's Avatar
use it all the time it cant hurt it can only help unless you yank the crap out of it when you put it on
Old Oct 19, 2007 | 05:10 PM
99grnmaxgxe's Avatar
Force of habit, use it all the time. lol
Old Oct 19, 2007 | 06:22 PM
bigpulve+'s Avatar
wierd since when I have my car jacked up I can rotate on front wheel and the other one will go the other way....that is in park on an auto....
Old Oct 19, 2007 | 06:39 PM
tonyrunna's Avatar
always use mine, keeps the stress off the auto tranny. especially parking in nyc.
Old Oct 19, 2007 | 06:44 PM
2AZN2DMAX's Avatar
^^^^ This is the best explanation yet. It does not mees up your transmission gears if you don't use e-brake. Doesn't matter if you use it or not. After that being said i use e-brake when I am on an incline/decline and turn my wheel left or right depending which way I park (incline=turn wheel away from curb and decline=turn wheel towards the curb).
Old Oct 19, 2007 | 07:46 PM
z32drifter's Avatar
You might also keep in mind, using the parking brake helps keep your rear brakes adjusted (not all cars but the Maximas style of rear brake caliper). That said, I always use the parking brake. Only exception is the wifes car in the garage, she never uses it. I use it if I'm going to be driving the next time someone gets in the car, but not is she will be the next driver.
Old Oct 19, 2007 | 07:48 PM
ajcool2's Avatar
My e-brake doesnt work so i cant use it. But I do in my Z.
Old Oct 20, 2007 | 03:55 AM
93SCMax's Avatar
98 SE
Most of the responses share why you use your e-brake. Would be interesting to understand why you don't use your e-brake (understanding that you don't use it if it is broken).
...Nissan engineers put it there for a reason, otherwise why not eliminate it and save $.
Old Oct 20, 2007 | 04:07 AM
pmohr's Avatar
No more Maximas...
Originally Posted by 93SCMax
...Nissan engineers put it there for a reason, otherwise why eliminate it and save $.
Are you serious?
Originally Posted by FMVSS 571.105 (S5.2)
. Each vehicle shall be manufactured with a parking brake system of a friction type with a solely mechanical means to retain engagement, which shall under the conditions of S6, when tested according to the procedures specified in S7, meet the requirements specified in S5.2.1, S5.2.2, or S5.2.3 as appropriate, with the system engaged--
It's a requirement for manufacturers...
Old Oct 20, 2007 | 08:54 AM
ROCKART's Avatar
wants an I35
regardless of automatic or manual, a parking brake is a neccesary item in at least a few scenarios.
if you are parking on a 25% grade (a steep hill) it would make sense to use your ebrake.
completely removing it from the design is not an option.
Old Oct 20, 2007 | 09:21 AM
maxima1239's Avatar
usually it keeps the stress of the transmission on inclines and declines.
Old Oct 20, 2007 | 09:48 AM
J-hop's Avatar
word, it is definately not good to have the gears sitting there w/tension on them. I personally use the E-brake all the time even if there doesn't appear to be an incline because its pretty hard to find dead flat road.
I dont think there is any merit to the arguement that it will somehow boil brake fluid. It actually should help dissipate heat away from the rotor better then air (air is an insulator!!!). The only time you must NOT use it is if your at the track and the brakes heat up beyond their normal operating temp, engaging the e-brake after you have been out racing can actually fuse the parkbrake to the rotor.
Old Oct 20, 2007 | 11:33 AM
MOHFpro90's Avatar
I dont but I need to.
This thread has a lot of useful information. Subscribed.
Old Oct 20, 2007 | 01:30 PM
MrDicks95SE's Avatar
Offset Is Everything.
i always use it no matter where i park.
Old Oct 20, 2007 | 01:48 PM
EnervinE's Avatar
i has college
A lot of overreaction in this thread. Think of the 80% of the public automatic drivers that never use their e-brake. It's called "Park" for a reason...it WILL hold your car, even on a moderate incline. How many times have you heard of "park pawl" failure?
Granted, I do use my e-brake on any sort of incline and a lot of places otherwise, but more for the ease of shifting out of Park than for the safety precaution.
Oh yeah, TONS of useful info here:
http://ask.metafilter.com/34398/Shou...rked-on-a-hill
