Coolant Temp Sensor
Old Nov 3, 2007 | 07:53 AM
Motorhead52's Avatar
Coolant Temp Sensor
I have a 95 max and keep getting Code 13. However, the CTS circuit is working perfect. Here is what I have done:
- Checked the sensor when the engine was cold and hot. The resistance measurements were right what they were supposed to be according to the FSM. Perfect.
- Checked the sensor ground at the connecter. Perfect.
- Checked the sensor ground at the ECU connecter. Perfect
- Checked for 5V coming from the ECU. 4.87V - The manual indicates this needs to be approximently 5V. Perfect
- Checked the continuity from the 5V line from the sensor to the ECU. Perfect.
- I used contact cleaner spray around various connecters and everything is shiny and new.
I'm also getting 707 (downstream oxygen sensor) but have just replaced it and cleared all the codes. Help!
Old Nov 3, 2007 | 08:13 AM
nafddur's Avatar
It seems like it would have been easier just to replace the coolant temperature sensor than go through the troubleshooting procedure you did.
I had the same code 9 years ago on my 95 Max, and for about $30 (including a 19 mm deep wall socket), replaced the sensor to solve the problem.
Old Nov 3, 2007 | 08:16 AM
Tatanko's Avatar
Bacon Lover
Despite your perfect readings, I would simply replace it. It isn't that expensive, and it's incredibly easy to replace. It's right in front of you in the engine bay and only requires the appropriate deep well socket or open-ended wrench. I've done it once before myself like nafddur, and he's right. This goes bad at some point on all A32's, it seems.
Old Nov 3, 2007 | 08:53 AM
ok well i look into replacing it then.
Old Nov 3, 2007 | 09:26 AM
heynow's Avatar
plus one
Old Nov 3, 2007 | 07:34 PM
19Maximus98's Avatar
I just did this repair today and it only take a few minutes. Be sure to keep a rag handy becuase there was some leakage when I removed mine, anti freeze leakage that is. I wasn't sure if you should use teflon tape but I did.
Old Nov 8, 2007 | 03:06 PM
Ok well I bought the sensor, I'm going to put in on saturday and see how it goes.
Old Nov 8, 2007 | 03:22 PM
nafddur's Avatar
This really is only a few minute job - most of your Saturday will remain available for other stuff. I guarantee that changing the sensor will take way less time than all the troubleshooting you went through to start this thread.
And, oh yeah, I saw zero leakage when I did mine. But the actual removal of the old sensor and screwing in of the new sensor takes only a few seconds, so maybe I just didn't notice a few drops of fluid leaking out.
Anyway, I hope this solves your problem.
Old Nov 8, 2007 | 07:40 PM
vqmaxman's Avatar
I would check for opened or stuck theromstates.
Old Nov 10, 2007 | 08:01 AM
oK i got the new sensor installed, going to drive around for the next few days if see if the error comes back
Old Nov 10, 2007 | 11:17 AM
I didnt have a deep socket, so i had to clear a few things out of the way first including the gauge sending unit. It took about 15 minutes to take everything apart and put it back in (i like having room to work) and there wasn't any overflow when I pulled the sensor out, so that was a nice bonus. So far no MIL but it took a couple days for it to come back on last time I cleared it.
Old Nov 17, 2007 | 08:10 AM
It has been a few days now, and the MIL light hasn't come back on since i replaced the sensor(knock on wood), so im going to declare this fixed. Thanks all for the help.
Old Nov 17, 2007 | 08:31 AM
jvckustumz's Avatar
what does it hurt if you don't replace it b/c ive had that code for about 2months and i always forget to replace it lol
Old Nov 17, 2007 | 08:51 AM
nafddur's Avatar
It's so easy and cheap to fix, why bother looking at that dopey light on all the time?
Old Nov 18, 2007 | 03:02 PM
If it goes really out of whack then it can be hard to start in the cold and use more fuel.
EDIT: Personally though, i just find the light bugs the hell out of me.
Old Nov 19, 2007 | 06:15 AM
jvckustumz's Avatar
oh ok, well i need to replace it but i am living by the week(money wise) and now i just bought a 7000. ring for my fiance so payments on that are added on to my other 35 monthly payments lol, can't afford it unless it hurts me bad lol
Old Nov 19, 2007 | 01:09 PM
wow man, all the money i ever spent on girls ever doesnt add up to half that. Mabey thats why im single though. If you just bought her a $6970 ring instead then she wouldnt have noticed and you would have had your sensor.
Old Nov 19, 2007 | 01:56 PM
jvckustumz's Avatar
i know huh
my03maxima
Jul 28, 2024 07:40 AM
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
