P0420 Code for CEL. Catalyst??
Old Nov 4, 2007 | 08:48 AM
MaxMateo5's Avatar
I got this code read at advanced auto parts. I have searched but did not find any aftermarket situations like mine.
I have had a Cattman Y-pipe for about a year, NO CODES at all.
A couple weeks ago I added a magnaflo CAT from Warpspeed (bolton) AND also a brand new Stillen Exhaust, everything was great for a day and then I got this code. reset it and it came back a day later.
I have cattman y pipe, magnaflo cat converter, and stillen catback. Any opinions of what is causing this?? Thankyou for your help!
Old Nov 4, 2007 | 08:49 AM
MaxMateo5's Avatar
BTW- this is a 1998 Nissan Maxima SE, I am pretty sure its FED spec car which I read could make a difference with this code.
Old Nov 4, 2007 | 10:40 AM
99BlackMaxMS's Avatar
I had it, and it ended up being one of my O2 sensors; the first one before the cat IIRC. It is a very trickey and mysterious code tho, many have been puzzled on it. Search about it as there have been threads on it over the last 6 months or so.
Old Nov 6, 2007 | 04:19 PM
castlemax's Avatar
I'm no mechanic, but it sounds like an o2 sensor. A friend of mine had this happen after he put an exhaust on his max, and it was his o2 sensor.
Old Nov 6, 2007 | 05:04 PM
KRRZ350's Avatar
I'm leaning towards your hi-flow cat being a worthless peice of crap
Old Nov 6, 2007 | 05:08 PM
MaxGordon7's Avatar
ever since i put on my budget b pipe my rear o2 always triggers, too much air flow ??!?!?!?
I had an upgrade 96 ECU in my 97 and it didnt trigger it. Maybe 97 ecu more touchy.
Old Nov 6, 2007 | 07:36 PM
67whitegoat's Avatar
I'm with KRRZ350. You gain nothing with a high flow cat and the magnaflow cat is a TURD. The insides will most likely come appart with in a few months and it is possibly the cause of your code. You may also check for intake leak after the MAF, exhaust leak before the cat, or a bad or leaking injector. Those are the main 4 causes for a p0420 (right bank, Three way catalyst does not opperate properly)
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
