check engine light help
Old Nov 9, 2007 | 07:41 PM
NElsonAQuino's Avatar
ok so i went to inspection.. failed.. got 3 codes back
p0325
p0130
p0171
i took it to the mechanic and he wanted to charge me 600$. i rather just buy the new ones myself and have him install it. what exactly do those codes mean? any help appreciated.
Old Nov 9, 2007 | 08:48 PM
pmohr's Avatar
No more Maximas...
You know, you could search, and find that out. Even generic googling would.
http://forums.maxima.org/showthread....ighlight=p0130
http://forums.maxima.org/showthread....ighlight=p0171
For starters...
Old Nov 10, 2007 | 08:12 AM
lexoid's Avatar
p0325
p0130
p0171
p0325 -- Knock Sensor/circuit
p0130 -- Front 02 sensor Bank 1
p0171 -- Fuel Sys lean Bank 1
All these codes are related to each other. Chances are that p0325 is a ghost code, 1st I'd check p0130 and p0171 codes. Check for vacum leaks, fuel pressure,injectors. Most probably the O2 sensor is gone. Do it yourself and save money. Google and FSM is your best friends
Good luck!
Old Nov 10, 2007 | 07:04 PM
gold4dsc's Avatar
i been having problems with my check engine light also thought i had everything fix and went to the inspection and failed it cause they said the check engine light wouldn't turn on. ( thinkin to my self can't pass wit it on and now its finally out they still won't pass it ) anybody know how to fix that?
Old Nov 10, 2007 | 07:05 PM
pmohr's Avatar
No more Maximas...
Bulb is probably burnt out, replace it.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
