FLYWHEEL Question
Old Nov 21, 2007 | 09:02 AM
eckounltd287's Avatar
Likes them corn fed
FLYWHEEL Question
Ok.
I had a Fidanza Flywheel and Exedy clutch in, about a year ago. 10K ago.
so i started getting some major Shaking in the vehicle, now in mostly every gear, except when i'm cruising. Only while accelerating.
So NOW i remember the mechanic told me " There is no timing ring with this flywheel" So he took off the Timing Ring from the stock flywheel and welded it on the Fidanza Flywheel, Can This cause the transmission's Shaking ??
Another mechanic told me that it's possible that the interior peices in the tranny weren't installed tight enough which could cause this shaking.( he did not open it, just from what i told him)
Any help would be appreciated
Old Nov 21, 2007 | 10:19 AM
mowgli29's Avatar
Horizontally opposed.
I didn't know the timing ring had to be welded on! I thought it could just be swapped...like bolt on er somethin. I'm getting a Fidanza any day now. I hope i don't have that problem!
Old Nov 21, 2007 | 12:17 PM
Likes them corn fed
Bump,
Please Help
Old Nov 23, 2007 | 08:13 AM
Likes them corn fed
Bump .....
10char
Old Nov 23, 2007 | 11:08 AM
kzoosho's Avatar
My fidanza came with the ring.
Old Nov 23, 2007 | 11:57 AM
Peebs187's Avatar
My ring bolted right on. To aggressive of a clutch and light weight flywheel could cause a list of long term problems.
Old Nov 23, 2007 | 01:05 PM
kzoosho's Avatar
yea i have never seen one that didnt come with the ring. Thats for the starter as well.
Old Nov 23, 2007 | 04:18 PM
MDeezy's Avatar
the timing ring can be bolted on, it does not need to be welded.
If your car has been fine for 10k with the welded lighten flywheel I highly doubt its causing a problem now.
If the clutch was installed properly it wouldn't be loose and causing a problem.
shaking could be the clutch slipping, look at the rpms and see if they are moving when u feel the shaking.
The fidanzas normally don't come with the ring, you'll have to use the stock ring off your flywheel for it to work.
Old Nov 23, 2007 | 04:42 PM
kzoosho's Avatar
Really? i have 3 of them and all came with them.
Old Nov 23, 2007 | 04:56 PM
MDeezy's Avatar
did you buy it from fidanza?
I've known many who purchased the flywheel and it did not come with the timing ring. Maybe they are including it now.
Old Nov 23, 2007 | 05:14 PM
kzoosho's Avatar
Yes from fidanza. And i just got my latest one in august and it came wih it.
Old Nov 23, 2007 | 05:24 PM
MDeezy's Avatar
nice... a few years back they weren't coming with it.
Old Nov 24, 2007 | 09:30 AM
Likes them corn fed
hmm. the car starts up fine. no slipping at all. the rpm's still move uppwards normally and the car accelerates fine, it just shake like motherfker
Old Nov 24, 2007 | 09:31 AM
Likes them corn fed
loose bearing in the tranny anyone?or maybe i didn't break it in right?
Old Nov 24, 2007 | 09:33 AM
MDeezy's Avatar
if you didnt break it in right, it would have showed that a long time ago.
possible trans
possible axles
hard to check for trans.
check your tranny mount?
actually check all your mounts
Old Nov 24, 2007 | 11:37 AM
kzoosho's Avatar
Honestly it could be a tire problem to say the least. I would start small and work my way up. Check your front end out i.e ball joints tie rods. Then go from there.
Old Nov 24, 2007 | 11:52 AM
Likes them corn fed
But the vibration only starts when there is power being delivered. When i press the clutch in the vibration goes away.
Old Nov 24, 2007 | 12:40 PM
khantalha+'s Avatar
definately the mounts man
Old Nov 24, 2007 | 12:58 PM
kzoosho's Avatar
Sorry man.
Old Nov 24, 2007 | 01:31 PM
KRRZ350's Avatar
Somethings coming loose............
That's my guess anyways Check the passanger side axle support, than flywheel-to-crank
Old Nov 24, 2007 | 01:52 PM
nlmaxima's Avatar
Check the front end and CV axles.
Old Nov 24, 2007 | 02:14 PM
Likes them corn fed
so i heard you were free next sunday
Old Nov 25, 2007 | 12:13 AM
OnEBadAsSi30's Avatar
My wheel bearings created my steering wheel to shake under any kind of acceleration. New wheel bearings tie rod ends and lower ball joints fixed the problem.
Old Nov 25, 2007 | 02:12 PM
Likes them corn fed
Oooo how much did all this work cost you
Old Nov 25, 2007 | 02:35 PM
kzoosho's Avatar
Ball joints and tie rods can be done at home. Wheel bearings are a press in so you can either have them pressed in or you can try at home.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
