Issue with 300zx calipers
Old Nov 24, 2007 | 01:48 PM
urmab's Avatar
Hello, I recently bought and installed 300zx calipers but I'm having an issue for some reason now my whole system does not have breaks the pedal doesn't seems to hold pressure its weird I thought it was air in the system but i bled the breaks about 5 times now still when the car is off after I pump the breaks there is some pressure build but but then when i turn the car on nothing. If anyone can help that would be great thanks
Old Nov 24, 2007 | 07:36 PM
MDeezy's Avatar
i cant remember but arent there two bleed screws per caliper on the ZX calipers? maybe your just bleeding one side of them.
Old Nov 24, 2007 | 08:26 PM
maximabebe's Avatar
There is only one bleed screw per caliper. When you installed them, is the bleeder screw on the top or the bottom. You may have them reversed.
Old Nov 24, 2007 | 08:41 PM
z32drifter's Avatar
^^^ My money is with you, I bet the bleeders are pointed down.
Old Nov 25, 2007 | 12:25 PM
urmab's Avatar
yes the bleaders are pointing down are they supposty pointing up?
Old Nov 25, 2007 | 01:25 PM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
Yeah, you need the bleeders on top. I ran into that problem too. Switch them around and you should be good to go.
Old Nov 25, 2007 | 01:39 PM
J-hop's Avatar
x2 i did the exact same thing, i must have spent $100+ on brake fluid trying to figure it out, its pretty easy to reverse them. just remember that air is bouyant so your bleeder screws always have to be in the highest point/pointing up to get the air out.
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Bonka
Sep 14, 2015 11:18 PM
bbsitum
Sep 11, 2015 04:55 PM
beerman1378
Sep 8, 2015 02:19 PM
