Three Wheel Motion
Old Nov 26, 2007 | 07:22 AM
aporozco's Avatar
Stock Airbox Supporter #3
Three Wheel Motion
Im driving home from work this morning. I learned yesterday that my ball joint is bad. So today it falls out, then as i make a cautious and steady turn to the right, my driver tire goes flying out from the wheel well down Grand Ave. Thankfully it didnt hit anyone. but now i think i need new parts. From obsevation....
-Disc
-Caliper
-Ball Joint
-Lug Nuts
-Hub
-Fender (hopefully I can find on painted Pebble Beige on here)
Total: $300
Labor Ill do myself.
P.S.
I shot my mirror with my paintball gun on accident as well. so I need to replace that. Its heated. Anyone got one?
Old Nov 26, 2007 | 07:36 AM
BLACKonBLACK98's Avatar
Former Vendor
man that sucks. i have some non-heated power mirrors, and someone in the 4th gen fs section has some heated ones.
Old Nov 26, 2007 | 07:37 AM
jvckustumz's Avatar
dude you got 2 threads over this one topic... wtf
Old Nov 26, 2007 | 08:44 AM
kzoosho's Avatar
SO you ball joint broke and your wheel fell off? Usually they both dont happen but i see it did.
Old Nov 26, 2007 | 09:20 AM
dgeesaman's Avatar
Maintenance Monster
Car disaster followed by a forum disaster.
If you're going to do this yourself, you'll really need to get one of those torque wrench thingies, and go back and retorque everything you've ever worked on before.
Dave
Old Nov 26, 2007 | 09:31 AM
hot_wax_tree's Avatar
well that sucks glad you're alright and that no one else got hit by your wheel. good luck with that all thos things arnt to hard to replace.
Old Nov 26, 2007 | 10:28 AM
IHAVEA2KMAXIMA's Avatar
i lol'ed when i saw ur 3wheel motion pix. i wasn't expecting that haha
Old Nov 26, 2007 | 10:50 AM
JSMax's Avatar
Sold
looks like it busted one of the studs and took another one with it?
hmmm looks more like you didn't torque the lug nuts properly.
Old Nov 26, 2007 | 12:36 PM
dblock1's Avatar
97' SE 5spd.
Goddddd dammmmmnnn bro what the F!!!!
I dont have any of those parts but let me know what else I can do...
Sorry dude!!
Yo shoot your friends car next time!!
Old Nov 26, 2007 | 01:27 PM
TunerMaxima3000's Avatar
how's the oil pan? front bumper?
SO im confused, did it actually break the ball joint or control arm, cause it just looks like your wheel was improperly installed and took the studs out when it broke, then possibly did other damage because of that.
Old Nov 26, 2007 | 02:20 PM
aporozco's Avatar
yea after futher inspection, i noticed that my ball joint is fine:
so i think my knuckle is bad which caused my hub to be messed up somehow. anyways i just need to replace the disc and the hub, possibly the knucle. oh and the fender.
Old Nov 26, 2007 | 05:32 PM
i'd be replacing studs / hub all round.
they may have been overtightend and stretched, i doubt that they were put on loose.
i can't believe after you heared the noise you didnt look to see whats up right away.
Old Nov 26, 2007 | 06:05 PM
andrei3333's Avatar
this is crazy, ive never seen anything like that before...
Old Nov 26, 2007 | 06:19 PM
aporozco's Avatar
so im damn sure that somehow the lug nugs were screwed up. in anycase all i need is a new hub and disc. oh and fender. but does anyone know if the hub can be replaced seperatly from the knuckle. the oil pan and fascia are fine. just the disc and lugs were broken.
Old Nov 26, 2007 | 08:59 PM
96i30azn's Avatar
Interesting story although by this picture, it looks to me like nothing's broken that could have cause your wheel to come off except one stud. This means that the breakage of 1 stud caused your wheel to come off. From that, I'll deduce the following story:
Someone hates you at work and decided to untorque 4 of the 5 lugs. These being on the left, would undo themselves everytime you brake until you only had one left.
Old Nov 27, 2007 | 05:14 AM
MDeezy's Avatar
actually two studs are broken and if it wheel wasnt tightened down, that make this outcome very plausable.
Sadly this same thing happened to me.... ahh memories
Old Nov 27, 2007 | 07:50 AM
aporozco's Avatar
in that pic the disc is angled because of dragging from the tow ttruck on and off. all of the studs were shorter, like snapped off and one was broken completely.
so you guys think someone loosened all four and one was holding it on. cause it was fine all weekend then driving on the highway on sunday i noticed a sound. then this on monday morning.
thanks y'all
Old Nov 27, 2007 | 08:13 AM
man your lucky your rotor didnt come off too
Old Nov 27, 2007 | 09:03 AM
99BlackMaxMS's Avatar
I have a heated passenger mirror. $50 shipped to you. Let me know.
Old Nov 27, 2007 | 09:50 AM
aporozco's Avatar
thanks a lot. PM'd
Old Nov 27, 2007 | 10:26 AM
aporozco's Avatar
does anyone know what size is the nut for the wheel hub. i dont have the wrench for sure but i wanna get one so i can take it off.
oh and this is what my wheel looks like
you guys think its still useable?
Old Nov 27, 2007 | 10:40 AM
cefiro8701's Avatar
sorry but i find the mirror incident hilarious...
sorry for the rest of it bud. good luck
Old Nov 27, 2007 | 01:51 PM
Adrian112597's Avatar
Adrian
36 mm, I'll lend it to you.
Old Nov 27, 2007 | 02:11 PM
Matt93SE's Avatar
STFU n00b!
1. you don't need a hub. just 5 wheels studs. they're about $1.50 each from the parts store.
pull the caliper and rotor off and you can change the studs by knocking the broken ones out with a hammer, then using some flat washers and a 12mm x 1.25mm nut to pull the new ones into place. you might run into some clearance issues with the dust shield in the back, but that's easy enough to fix with tin snips.
2. clean the crap off the rotor and see if you actually need to replace it. if it's just scratched on the corner, clean the stuff off and drive away. probably didn't ruin it.
3. throw that wheel away. I wouldn't trust it except for $5 in scrap metal. those things are cast aluminum and pretyt thin in the area yours got gouged up. replacements are pretty cheap at a junkyard.
4. whoever the person was that last mounted that wheel, DON'T EVER LET THEM TOUCH YOUR CAR AGAIN.
Old Nov 27, 2007 | 02:15 PM
What if he was the one who last mounted the wheel.....
haha just kidding.
Old Nov 27, 2007 | 02:22 PM
hectorc's Avatar
Upper Midwest Wheel Whore
Actually, I'm thinking he was the last person to mount it
Just do what Matt said.
Old Nov 27, 2007 | 02:23 PM
Buck96's Avatar
Dude that suck, but these threads keep getting funnier and funnier,
Glad I'm selling mine
Old Nov 27, 2007 | 03:03 PM
CRiME's Avatar
oem ftw!
maybe he was drunk some other night and decided to shoot at the wrong person with his paintball gun? on the bright side man, pretty sure you have the lowest max in IL right now
hope you get it sorted out
Old Nov 27, 2007 | 08:06 PM
aporozco's Avatar
i did put those front wheels on when i rotated them. but my mechanic said my bearings went bad cause of misalignment. same thing happened to him once. i wish i read about replacing the stud cause now im getting it towed into the city to fix it all at my moms shop for like $270.
Thanks tho
Old Nov 27, 2007 | 08:10 PM
MDeezy's Avatar
bad wheel bearing would become very loud, you would have known something is up cause you would have heard it (unless you bumper the music loud all the time)
studs are extremely easy to replace. a couple bucks a stud, and takes about 10 min (if you were doing all 5 at one).
Old Nov 27, 2007 | 08:14 PM
Apparition's Avatar
Ichiban King
whoa WTF..
Old Nov 27, 2007 | 08:26 PM
aporozco's Avatar
yea it was really loud. like i was bumping and i heard it clearly. it started quiet and got extremely loud within one day till fall off.
Old Nov 27, 2007 | 08:30 PM
aporozco's Avatar
actaull i wont do it myself. but this sadly will def postpone my purchase of the shocks til after the holiday. im really pissed.
Old Nov 28, 2007 | 01:55 AM
pmohr's Avatar
No more Maximas...
And when you started hearing all of these noises, you didn't think to look over anything?
Old Dec 11, 2007 | 04:15 PM
aporozco's Avatar
okay so car has been fixed for about a week or more now. but i still hear some sort of grinding/rubbing. i should say that i did not replace the pads, but they did replace the shock tower for some ungod known reason.
so...
hub/knuckle/control arm i think
disc
lug nuts
shocktower
fender/lining
(old parts are in my trunk)
these are what were replaced. and my mech is some sort of perogi and said it was my brakes and itll go away but it hasnt. also i corrected my dust shield but it still makes noise.
hey thanks y'all for the advice
Old Dec 11, 2007 | 11:03 PM
96blackmaxSE's Avatar
boost me.....
1.
Whats wrong with the wheel, only the inside is scraped up a little bit...Its not like the wheel malfunctioned......
Old Dec 11, 2007 | 11:07 PM
boost me.....
oh yeah...
Old Dec 11, 2007 | 11:49 PM
MaxGordon7's Avatar
I'd have to say lug nuts, but you would feel the wheel wobble all over when steering and the loud *** sound.
No way a ball joint did any of this. Bad ball joint is easy to pick out. Jack car up, now just shake the tire a bit and if it moves side to side(not so hard you move the steering wheel) the ball joint is not doing its job and needs replacement. It just keeps the wheel straight and cannot be align if you have a bad ball joint. I drove on one for half a year before a mech told what it was, it didn't feel solid.
Can a hub bearing just freeze up and break all the studs?
Old Dec 12, 2007 | 05:48 PM
aporozco's Avatar
naw my ball joint is fine as far as i know. but it is hard trying to check my **** when its like 15 degrees out side. but where are you located? im near SE wisco and used to work in pleasant prairie.
Old Dec 12, 2007 | 05:57 PM
19Maximus98's Avatar
Somebody got owned by those little gremlins on the Geico commercial.
Sorry dude, that does suck. I remember back in High School a buddy of mine had this samething happen to him. His girlfriends ex-boyfriend loosed his lug nuts while in class. About a 1/2 mile into his drive home off comes the wheel and he slid a good 80 feet on one front rotor. Man was he pissed.
