white clock mod question
Old Nov 27, 2007 | 06:42 AM
jvckustumz's Avatar
ok i have used the search feature but it is not giving me a definate answer to my problem, ok you use red cellophane right?? i used it and it made my clock pink not white... is my cellophane too dark or whats the deal?? thanks
Old Nov 27, 2007 | 07:43 AM
Cdg2125's Avatar
Why don't you try changing the cellophane first and see what happens with a darker or lighter red? Nobody know's how dark your paper was, or the quality or anything. How could we tell you the problem?
Old Nov 27, 2007 | 07:47 AM
jvckustumz's Avatar
because i asked if it was red cellophane that you used just to make sure
Old Nov 27, 2007 | 08:05 AM
hot_wax_tree's Avatar
maybe put some pics up that would make it easier
Old Nov 27, 2007 | 09:29 AM
Cdg2125's Avatar
yes red cellophane will change the green to white. But you just need a different shade probably.
Old Nov 27, 2007 | 10:12 AM
cefiro8701's Avatar
i used pink and it made white....hmm....
Old Nov 27, 2007 | 10:14 AM
ROCKART's Avatar
wants an I35
yea sounds like ur red is too red.
Old Nov 27, 2007 | 10:19 AM
Cdg2125's Avatar
ha fair enough. Point is that he should be testing colors before asking others what's wrong with his. Pink really? never heard anyone using pink. Interesting.
Old Nov 27, 2007 | 10:23 AM
KRRZ350's Avatar
So...............
Who's the cool guy in this thread? Ya' know, the one with a color wheel...........
What makes orange from green?
Old Nov 27, 2007 | 10:38 AM
cefiro8701's Avatar
it was laying around the house right after christmas three years ago. it worked but it's really in between blue and red...but not baby blue or aqua.
check it. it's a little bluer than it is usually must be because of the long exposure.
Old Nov 27, 2007 | 10:40 AM
Cdg2125's Avatar
Originally Posted by KRRZ350
So...............
haha i've been trying to figure that out! I was thinking of doing orange led's interior ha
Old Nov 27, 2007 | 10:41 AM
cefiro8701's Avatar
frick...i think that makes yellow...
even if it make orange...would that make your interior look like its covered in CEL's?
Old Nov 27, 2007 | 10:46 AM
KRRZ350's Avatar
Well the illumination on my pathfinder hu is orange, and now I have the matching orange gauge cluster (Blends in nicely with the cel & abs lights, lol) But an orange clock and climate control would be the perfect touch.
I think I've got it though! If pink makes white, than orange will make........ ah...... orange?
Old Nov 27, 2007 | 02:42 PM
EnervinE's Avatar
i has college
Better yet, use pink to make it white, THEN use orange on top to make orange. Hell, while you're at it, make your clock rainbow.
Old Nov 27, 2007 | 03:04 PM
KillaJakez's Avatar
I used a dark pink, I guess a magenta type of cellophane. It turned the clock to a very pale blue, but not white. I did the climate control too.
By
Old Nov 27, 2007 | 03:17 PM
jojo98maxima
By
this set up looks very nice
castlemax's Avatar
For the clock to be white, you have to use a pinkish-red celophane since the clock is a light green.
Old Nov 27, 2007 | 04:11 PM
rockfordmaxII's Avatar
a little off topic, but when you turn your headlights on during the day, and then if you cant see the readings on the climate control you turn the instrument panel switch all the way on to make all the lights in daytime mode, well, my climate control gets bright, but my clock stays dark. It will be bright without the lights on during the day, but at dusk when i turn on my lights just the cllimate control gets bright and not the clock, it goes dim....any ideas?
Old Nov 27, 2007 | 04:54 PM
Maxima_Joe's Avatar
4th Gen Parts King
The dimmer wire needs to be cut it is the red wire with the blue tracer on the plug for the clock.
Old Nov 27, 2007 | 08:00 PM
OnEBadAsSi30's Avatar
Simple Physics.....You mix Red, Blue, Green=White. So use red and blue cellophane Actually i've never tried to change my clock cause I like green. I was just wondering if that would even work and/or to see what your guys insight on using two different colors of cellophane was.
Old Nov 27, 2007 | 08:04 PM
well, if i do that, will it stay on bright all the time? with the stock wiring, shouldnt the clock follow the same brightness as the climate control?
Old Nov 27, 2007 | 08:17 PM
Not if you do the Always Bright Clock mod in the stickys. Its just cutting one wire.
Old Nov 27, 2007 | 08:58 PM
BlackMaxdout's Avatar
So...............
I've never laughed so hard in my life.
Old Nov 27, 2007 | 10:31 PM
KillaJakez's Avatar
Thanks!
Old Nov 27, 2007 | 10:54 PM
cefiro8701's Avatar
you bungholes made me realize that my climate control buttons don't light up anymore.
Old Nov 28, 2007 | 01:48 AM
pmohr's Avatar
No more Maximas...
Err...physics?
Old Nov 28, 2007 | 07:21 AM
Mine don't either
Old Nov 28, 2007 | 07:26 AM
jvckustumz's Avatar
Originally Posted by pmohr
Err...physics?
physics of a color wheel
Old Nov 28, 2007 | 09:57 AM
well yeah it will be allways bright but i dont want to be blinded when its pitch black outside. so is there a way i can get it to follow the same brightness as the climate control?
Old Nov 28, 2007 | 10:12 AM
Cdg2125's Avatar
kidding right? it doesn't get brighter....it stays bright. Not like you cut that wire and the led light all of a sudden puts out more power...
Old Nov 28, 2007 | 02:12 PM
shissqbob's Avatar
hahaha this thread is amazing. physics=art
Old Nov 28, 2007 | 02:33 PM
i understand that its not going to get brighter than it is during the day, but it dims at night when the lights are turned on so that its not super bright at night. All i was asking was if the clock lights should follow the same brightness as the climate control when the dimmer switch is turned all the way up with the lights on.
Old Nov 28, 2007 | 05:12 PM
Here's an idea: Run a jumper from the climate control to the clock so that it works the same way.
Old Nov 28, 2007 | 08:11 PM
KillaJakez's Avatar
You want to make it white too right? Cut the wire, and see how you like it. If it is too bright, then add a few more layers of cellophane. It will get dimmer accordingly. Problem solved.
Old Nov 28, 2007 | 09:31 PM
KRRZ350's Avatar
Haha, thanks, allthough my Q still hasn't been answered, but here's what I have so far..........
R+G+B=White So, that means- R+B=White clock light, and since R+B=Purple, than Purple is the color really needed to make it white........ SO, I've got Purple + Orange = Orange clock.
But to avoid multiple layers of cellophane, all I'd like to know is what Purple + Orange makes!! because than clock light + X = Orange clock light.
Old Nov 28, 2007 | 11:00 PM
Cdg2125's Avatar
it's not even bright! It's never super bright ever. I don't know why you're thinking that. And yes, when you paper behind it it will get dimmer. You'll probably have trouble reading it after doing the cellophane more than 1 layer.
Old Nov 29, 2007 | 10:51 AM
ZachsMax's Avatar
Ridin' Spinnaz
Anyone know a good combination to make it red? I'd assume you'd have to use several layers of white then red, but I've been told it can be quite a PITA to match up.. I don't want TOO many layers, or the clock might be too dim during the day.
Old Nov 29, 2007 | 10:56 AM
Cdg2125's Avatar
why don't you try some things out? Two layers of red should create a red light. But you have to find the right color of red to get red and not pink or another color. Do some work and see what you get.
Old Nov 29, 2007 | 08:42 PM
EnervinE's Avatar
i has college
Make sure you guys know what you're getting into if you attempt to do this mod. Changing the color of your clock using gift-packing material from Hobby Lobby is serious business.
Old Nov 29, 2007 | 10:47 PM
black_maxed95's Avatar
you want to make sure to get this right the first time cause there is no goingback once you do it
