? for changing/noise from suspension
Old Oct 24, 2001 | 12:19 PM
Toolrocks's Avatar
Wanted to know if the car rides a little rougher when you put the spiral wrap on. It looks like it would effectively remove some of the springs traveling room. My car ride is rough but tolerable - the clinking noise however is embarrassing so I will probably be using the spiral wrap or buying the part from Courtesy. That raises another question. WIll the factory tubing fit the diameter of Intrax's springs? Thanks for any responses.
Old Oct 24, 2001 | 12:37 PM
njmaxseltd's Avatar
No change at all in ride. The spring coils are already sitting on top of each other. All your doing is isolating them so you don't have metal to metal contact. The thickness of the Wire Wrap is about 2mm
Old Oct 24, 2001 | 01:10 PM
Toolrocks's Avatar
Thanks, and great write up in the sticky.
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
