o2 Sensor on Cat!
Old Dec 2, 2007 | 03:07 PM
EpzMaxima96's Avatar
o2 Sensor on Cat!
Ok guys quick question. Both my upstream o2 sensors are brand new I just replaced them but still havent install the o2 sensor on my Cat. Will the downstream (o2 sensor on cat) o2 sensor make my car bog in low rpms? I have a bog and that the only o2 sensor I have left.
Old Dec 2, 2007 | 03:10 PM
mowgli29's Avatar
Horizontally opposed.
nope. that o2 sensor is only for emissions. it just makes monitors your cat to make sure it works correctly.
Old Dec 2, 2007 | 03:11 PM
NmexMAX's Avatar
dot dot dot ...
No, rear O2 has no affect on performance.
Old Dec 2, 2007 | 03:19 PM
ScottS's Avatar
Where are all the O2 Sensors and which ones effect what?
Old Dec 2, 2007 | 03:26 PM
there's 2 on the y pipe and 1 on the cat...my car is still bogging and is being ridiculous what could this be? I have no clue what's wrong the only codes im getting where the o2 sensors...anyone have any idea what I should do?
Old Dec 2, 2007 | 03:35 PM
mowgli29's Avatar
could be alot of things. how/when does it bog? describe pls.
Old Dec 2, 2007 | 03:37 PM
it bogs around 2k-4k anywhere around that in no specific gear and it goes away if I give it gas but if Im steady driving it sometimes starts to jerk and bog and If I come to a stop it either stalls or I have to keep on the gas. I replaced both upstream o2 sensors, fuel filter, and spark plugs. Im not gettin a tps sensor code but I went out and bought one for cheap and havent installed it but could the tps be doing this also?
Old Dec 2, 2007 | 03:39 PM
kzoosho's Avatar
Have you cleaned the maf?
Old Dec 2, 2007 | 03:54 PM
how do I go about cleaning the MAF?
Old Dec 2, 2007 | 04:20 PM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showthread.php?t=347177
Old Dec 3, 2007 | 08:33 AM
nanomax96's Avatar
I would also check for vacum leaks on your intake. I had the same exact problem and it turned out one of my hoses on my intake between the MAF sensor and throtle body was loose. I tighten it up and the problem was resolved.
Old Dec 3, 2007 | 08:49 AM
Double E's Avatar
Good advice so far....
Clean the KS connection to the valve cover gaskets too.
Have you cleaned the TB? Mine bogged & got terrible mileage till I did that. I cleaned the IAC too but it didn't give as significant a result as the TB. (Use new gaskets if you do this.)
Beyond that....toss in a bottle or 2 of BG injector cleaner or some Techron?
my03maxima
Jul 28, 2024 07:40 AM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
