Rear power window DROPS down into the door
Old Dec 4, 2007 | 07:16 PM
JoshBarber's Avatar
My girlfriends 96 Maxima has a new problem.
I'm hoping its a common issue, with an easy fix...so I'm throwin' it to you guys.
The rear power window on the drivers side no longer works. The window drops freely back into the door, and won't come back up. I took the door apart this evening to try to fix it but had a hard time in the dark with just a flashlight and mirror. From what I could tell, there's a cable that coils on a wheel. It lets slack out to lower the window, and tightens the slack to lift it.
The cable seems to have a little "nub" for lack of a better term that I assume should be somehow attached to the window bracket where it rides in the track. Unfortunately, the only time it catches on the window is when the button is pressed to lower the window. When the "nub" reaches where the window bracket is, it forces the window downwards. But when the button is pressed to bring it back up, it doesnt grab the window at all.
Any help would be greatly appreciated.
Old Dec 4, 2007 | 07:22 PM
Olezhka's Avatar
you need to replace the window regulator. Just the regulator, not the motor.
should be like $20 at a junk yard. It's really easy to replace.
Old Dec 4, 2007 | 07:54 PM
JoshBarber's Avatar
is there a how to somewhere?
what part is the regulator? every car Ive worked on, the regulator was the motor
Old Dec 4, 2007 | 08:04 PM
Olezhka's Avatar
this is it
You can use the same motor you have now.
I don't know if there is a write up, but trust me, it's really easy.
Just take off the door panel and you'll see. It's pretty self explanatory.
Old Dec 4, 2007 | 08:23 PM
Nopike's Avatar
JoshBarber it's a good thing your girlfriend has all these problems with her Max. Sounds like it probably keeps you busy and out of trouble. LOL
Old Dec 4, 2007 | 08:25 PM
Nopike's Avatar
JoshBarber have you had any luck with that hesitation/misfire?
Old Dec 5, 2007 | 04:15 AM
JoshBarber's Avatar
no luck with the hesitation. I dont believe its a misfire. I havent pursued it honestly
Old Dec 5, 2007 | 06:48 AM
JoshBarber's Avatar
this is it
anyone able to get them from a shop like autozone or similar? local AZ charges $45.99 for a new one. if its a common break, I don't think I want to use a junkyard part if I'm taking the time to replace it
Old Dec 5, 2007 | 09:45 AM
Olezhka's Avatar
ebay it
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
shaunkey1
Aug 18, 2015 10:09 PM
kjm900r
Aug 5, 2015 07:14 AM
