need assistance with steering problem...
Old Dec 17, 2007 | 12:26 PM
JUS10's Avatar
ok, so heres the deal. first off let me tell you what I have replaced, I replaced the inner and outer tire rod. When I first had it checked, my steer was pulling to the left, they told me I needed the inner tire rod. when it was replaced, it then pulled more to the right. I had no charge for the alignment because they said the alignment was still off and it was the rack and pinion, or whatever it is. So I then took it back agian, then this time they said it was my outer tire rod. Well you know whats coming............my car steering feels exactly the same, no diff. my car still pulls to the right a little. My question or concern is, number one, If my car is aligned, should the steering wheel be in the middle or somwhat close to the middle in order to be aligned or can the car be aligned with (how my steering wheel is) the wheel off to the left about 5-7 inches? Number 2, were those replacements even needed to help the situation out?
Im sorry about the long post, My ideal outcome would have been to leave there with my wheel centered and aligned with my tires. Thanks for any help!!!!
Old Dec 17, 2007 | 12:53 PM
JtzMax's Avatar
Whatchyou say?
have you check tire pressure?
just how would you feel if that was it? ROFL
it could also be a broken belt in the tire or a bent rim.
Old Dec 18, 2007 | 05:54 AM
njmaxseltd's Avatar
Your should get the car back with a centered steering wheel after it's aligned.
Pulling issues are related to tires, camber and caster, not toe.
Did you get the report from the shop with your alignment specs? You should get a print out of exactly how the front end is set up. Post those specs so we can see how the car is tracking.
Old Dec 18, 2007 | 09:47 AM
heynow's Avatar
Hi guys, i don't mean to hijack this thread, but i'm in exactly the same boat as JUS10. I've replaced ALL (and i do mean all!!) suspension/streering components (except for the rack). The car pulls to the right past 25mi/hr (i even have to steer to the left a slow speeds sometimes)
I THINK that it started happening when i got new Bridgestone potenzas last winter. I'm not sure however, seeing how i was replacing every suspesion part @ the same time.
In any case, multiple allignments @ Firestone (i know, they suck) and NTB, yielded no results. NTB said that the front-end is 100% straight and even rotated my tires for free. But still the same darn thing!! I'm tired of having replaced all of the front-end parts and still having to keep the teering wheel to the left!!!
Should i try some HS balancing, or it wouldn't matter?
Old Dec 18, 2007 | 05:28 PM
njmaxseltd's Avatar
heynow - Post your alignment specs from the print out you got from Firestone.
Balancing doesn't effect alignment, pulls ect. Just vibrations.
Old Dec 18, 2007 | 09:22 PM
heynow's Avatar
I'll scan that tomorrow morning.
Old Dec 19, 2007 | 09:59 AM
heynow's Avatar
Here you go guys, my last allignment results. Sorry for the late posting.
http://www.putfile.com/pic.php?img=7315395
Old Dec 20, 2007 | 07:12 AM
JUS10's Avatar
alright guys i have been away for a while, anyhow, i will post the alignment specs asap, so we can see whats going on. thanks.
Old Dec 20, 2007 | 07:47 AM
heynow's Avatar
do that
Old Dec 20, 2007 | 08:31 AM
91parkave's Avatar
have they checked for the rear toe in/out spec? that could be why your still pulling to the right, also are your strut mount/bearings in good shape, if not they could cause a caster issue which would cause your probem as well.........
Old Dec 20, 2007 | 09:17 AM
heynow's Avatar
I dunno about JUS10 , but all of my suspension components are new (including strut mouns & bearings)
my allignment specs are posted if you're interested
Old Dec 21, 2007 | 06:34 AM
njmaxseltd's Avatar
heynow - your specs look fantastic, very well setup and even left to right.
Old Dec 21, 2007 | 07:54 AM
heynow's Avatar
Thanks I'm flattered I guess that's why they said it couldn't BE anymore straight, lol. NTB seems to do a good job.
But the problem is that the darn thing pulls to the right like a ****. I always have to keep the steering wheel cocked to the left by 2 inches. It starts "drifting" to the right past 20mi/hr and then gets a 'lil worse past 35 and i still have to keep left a bit past 60.
Old Dec 21, 2007 | 08:00 AM
91parkave's Avatar
screw that have them throw the car back on the rack and re-check all your suspension values, yes even computers **** up sometimes
Old Dec 21, 2007 | 08:12 AM
heynow's Avatar
That print out is actually the 3RD (yes, THIRD) allignment i've had done within a 2-month time period. I still have some time left on their 6-month guarantee, but i doubt they would do anything different this time.
Old Dec 23, 2007 | 09:44 PM
heynow's Avatar
Any updates on your part, JUS10 ?
Old Dec 23, 2007 | 10:07 PM
mevjen's Avatar
The self-oil changing max
I had a bad pull problem, I rotated my tires and it helped a lot. Maybe you just have bad tires?
Old Dec 29, 2007 | 09:46 AM
heynow's Avatar
I did that, same thing. Who knows, maybe my tires just suck.
Fbana41
Aug 29, 2016 12:18 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
