HEY GUYS WHATS THE WIDEST TIRE YOU CAN GO ON A MAXIMA SO IT WOULDNT RUB.....
Old Dec 28, 2007 | 12:07 PM
The Russian's Avatar
i am about to buy another max this saturday......i wanted to see how wide i can go...i was thinkin 19 x8.5 rims...but how wide tires can i go? and wat do you guys recomend? i was thinkin 245 45 19? any1 have any opinions? or suggestions?
Old Dec 28, 2007 | 12:38 PM
hello desert.org....any1? lol
Old Dec 28, 2007 | 12:51 PM
hectorc's Avatar
Upper Midwest Wheel Whore
I think there have been plenty of threads asking if a tire will rub in the past week. Out of boredom I will shed some light on the subject. 19x8.5 should fit fine, but you may need something with an offset of lower than 40. I have heard some guys running 9.5" rims on back. For the tire at 8.5 I would go with something like 255/40/19. 245 might be a lil small for the rim, and getting 45 in height might rub alil when turning.
Old Dec 28, 2007 | 12:54 PM
It's only been 31 minutes, and you're bumping your thread? It was still in the top ten threads in this forum.
IMO, you would have had better luck posting in the Tires and Wheels Forum. Hopefully a mod will move it for you.
Old Dec 28, 2007 | 01:08 PM
i havnt been on the org for a while every1 is so bleh about everythin ...cmoN wiz....lighten up...and right on hector for your input....you think the car being dropped would affect it?
Old Dec 28, 2007 | 01:19 PM
hectorc's Avatar
I was considering a drop, therefore answered accordingly.
Old Dec 28, 2007 | 01:25 PM
4sho....they made an exact replica of the milli miglia's every1 is crazy over...
http://www.tirerack.com/wheels/Wheel...Silver+Painted
they look sweet!
Old Dec 28, 2007 | 01:43 PM
Maximeltman's Avatar
415 415....FRISCO?? 19x8.5" tires... FRISCO BALLIN RIGHT THERE YEEEEEEEEE SUNSET DISTRICT ON MINE.
Old Dec 28, 2007 | 01:53 PM
DrunkieTheBear's Avatar
Turbo'd Saab
I have 17x9s with 255's no rubbing I could go 265 really but I would only have about 3mm of clearance, and that just doesn't seem like a good idea
Old Dec 28, 2007 | 02:29 PM
Digitized's Avatar
well it would be easier to answer your question with the following:
what offset will the rims be?
are you dropped?
if so, how much of a drop?
Old Dec 28, 2007 | 03:06 PM
Ahheck01's Avatar
Also, what's the purpose? Going too big and wide with your wheel/tire combination can hurt both performance and comfort, and past a certain point, even the appearance of the car. Bigger != better, universally...
-Evan
Old Dec 28, 2007 | 03:50 PM
NmexMAX's Avatar
dot dot dot ...
So, when are you going to post the wheel offset & width?
Old Dec 29, 2007 | 01:46 AM
Offset: 48mm Bolt Pattern: 5-114 Size: 19 x 8.5......?
for a 4th gen max!
Old Dec 29, 2007 | 01:58 AM
MorpheusZero's Avatar
48mm... get like 15-20mm spacers, then you'll be good to run up to 255s or so.
Old Dec 29, 2007 | 02:31 AM
NmexMAX's Avatar
dot dot dot ...
You'll be fine, no rubbing. And that bolt pattern should be 114.3.
LilVito
Oct 25, 2019 08:12 AM
MplsMadMan
Sep 4, 2015 02:23 PM
Jcof88
Aug 3, 2015 10:43 PM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
