is there a working HOW TO for install strut bars? any1?
Old Jan 28, 2008 | 09:10 PM
The Russian's Avatar
im wondering i have a strut bar layin around for the max....can i put it on without lifting the car? jus unscrew the things that connect to shocks and put it there and then jus tighten em? or is that a unsafe choice and shud have it installed somewere?
Old Jan 28, 2008 | 09:13 PM
maxx0831's Avatar
yea u can put the bar on jus leave the car on ground though and the wheel straight. Thats what i did and no problems
Old Jan 28, 2008 | 09:17 PM
and its safe? im just scared that if i do it.......then will have an issue w me not being able to tighten it as hard as it needs 2 be.....
also what tool did u use to take it off? my buddy asid just bring it to a shop....and use a tool for removing lug nuts.
Old Jan 28, 2008 | 09:30 PM
wiggafly808's Avatar
Haha dude you dont need to take it to a shop..
This is like 30x easier than an oil change.
Use a standard ratchet set, unscrew one side, put the strut bar on, tighten the bolts, repeat for the other side.
There honestly isnt much to mess up at all.
You dont have to worry about overtightening as long as you dont strip anything, just make sure its snug.
Old Jan 28, 2008 | 09:33 PM
pmohr's Avatar
No more Maximas...
No need to do just one side at a time, it's easier to do both sides of the bar at once.
6x14mm head nuts, done.
Writeup? Seriously?
I can make one right now if you'd like...
Old Jan 28, 2008 | 09:36 PM
Yeah.. it doesnt matter either way, its just easier so you dont lose any nuts.
Old Jan 28, 2008 | 09:56 PM
its really that easy?
Old Jan 28, 2008 | 09:59 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Are you asking this in regards to installing a FTSB (Front Tower Strut Bar)?
Old Jan 28, 2008 | 10:05 PM
pmohr's Avatar
No more Maximas...
*FSTB (Front Strut Tower Bar)
Nope, we lied.
Old Jan 28, 2008 | 10:07 PM
yea.........the front strut bar....i have one laying around from my old maxima....and i wanetd to put it on...but i dont remmeebr how i got my old one on.....also wnated to ask.....is it gonna be tight enough when u wrench it back with my hand?and will it need bigger strut bolt things? thanks for the quick replys and help guys
Old Jan 28, 2008 | 10:10 PM
SEmy2K2go's Avatar
Go BUCKS!!!
lol...yeah, that too.
INSTALLATION INSTRUCTIONS FOR MAXIMA FRONT STRUT BARS
1 - Park vehicle on a level surface and open the hood to access the engine bay.
2 - Locate the three (3) upper shock absorber mounting nuts on each strut tower (left and right)
A. Remove the three (3) upper shock absorber mounting nuts (gold in color) for each side.
B. Install the left and right END-PLATES on the protruding shock absorber mounting studs.
Do not tighten the nuts yet, leave them loose.
C. Insert the MAIN BOLTS into the BAR UNIT.
Use END-PLATE bolts/nuts to connect the END-PLATES to the main bolts,
tighten only these END-PLATE bolts/nuts.
D. Adjust the distance between left and right END-PLATES by turning the BAR UNIT.
E. Use ADJUSTER NUTS to tighten MAIN BOLTS to the BAR UNIT.
F. Tighten the shock absorber nuts with a torque wrench to 35 ft/lbs, to fasten the END-PLATES along with shock absorbers to the car.
! ! DO NOT FORGET ABOVE STEP ! !
FAILURE TO DO SO IS EXTREMELY DANGEROUS
G. Tighten all bolts/nuts properly to complete installation.
http://www.courtesyparts.com/html/inst_a33_stb.html
Old Jan 28, 2008 | 10:13 PM
pmohr's Avatar
No more Maximas...
You mean just hand tighten them? No, that's idiotic. Use actual tools.
No, you won't need longer studs, unless for some reason the end plates on your FSTB are obscenely (Ron Jeremy style) thick.
Old Jan 28, 2008 | 10:14 PM
5 stars!!!!!!!!! THANKS!
Old Jan 28, 2008 | 10:15 PM
i ment hand tightening with tools...vs a machine tool.(like a wheel lug tightener)
Old Jan 28, 2008 | 10:19 PM
pmohr's Avatar
No more Maximas...
Do what?
You mean like a torque wrench?
Old Jan 28, 2008 | 10:22 PM
yea
Old Jan 28, 2008 | 10:24 PM
pmohr's Avatar
No more Maximas...
yea
It's best to properly torque them, but you don't need one to do the job.
Old Jan 28, 2008 | 10:41 PM
MorpheusZero's Avatar
Torque for the upper strut mount nuts (only nuts you need to remove to install) is about 25ftlbs IIRC (could be 35 per the writeup, it really doesn't matter TOO much), so pretty much just "good and tight" with a regular socket wrench but not beyond that, use just a little bit of muscle after they are snug.
Old Jan 29, 2008 | 06:50 AM
Coolsaber57's Avatar
Anyone else having trouble getting the nuts off? (sorry that sounded )
I think i'm going to need to pick up a breaker/cheater bar for this, I tried with just a wrench and couldn't do it.
Old Jan 29, 2008 | 06:54 AM
ROCKART's Avatar
wants an I35
spray some wd40 or silicon on there and tap it with a wrench. mine were stuck on too, just gotta get em moving a little and you can overpower the rest.
Old Jan 29, 2008 | 07:23 AM
merlin2375's Avatar
pb plaster/liquid wrench will get them moving, easy job...
Old Jan 29, 2008 | 09:57 AM
vajguy's Avatar
I just use a 1/2'' rachet with a 14mm socket and those bolts came right off. No need for a breaker bar if you have a 1/2'' rachet.
Old Jan 29, 2008 | 07:57 PM
KRRZ350's Avatar
Actually that write-up sucked.
You'll get much better, RE: actually noticable, results if you jack the front up by the center x-member and tighten the bar fully outwards before lowering.
Old Jan 30, 2008 | 07:11 AM
phenryiv1's Avatar
Mod her. Ate her.
Originally Posted by mowgli29
how does a thread like this turn into 2 pages?!?! shoulda been locked long before then..
It gets to two pages because I have a life and don't live on the org.
Move along, people.
Old Jan 30, 2008 | 08:07 AM
EnervinE's Avatar
i has college
Move along, people.
Spoilsport.
Old Jan 30, 2008 | 08:18 AM
mowgli29's Avatar
Horizontally opposed.
sorry, wasn't attacking the mods...just wondering how/why so many people post in threads like this...
Move along, people.
Old Jan 30, 2008 | 09:22 AM
ajcool2's Avatar
IB4TL
Old Jan 30, 2008 | 07:45 PM
uhh...wtf is on ur headlights lol.
Old Jan 31, 2008 | 12:34 PM
antilley's Avatar
Not trying to be a smart ***--but, after reading the thread I think you might want to add a step to put the nuts back on BEFORE jacking up the front of the car.....
Old Jan 31, 2008 | 04:47 PM
bigpulve+'s Avatar
Mine were put on so hard that I had to take it to a shop and they needed 10 mins, pb blaster and a 300 lb foot air gun to get mine off.
I broke a socket trying on my own...
this was in june of '06
Old Feb 22, 2013 | 09:34 AM
fernnizy1720's Avatar
im my 99 maxima on the driverside strut theres like a lil thing welted to it and it doesnt let the bar on in right..... is there a problem if i bend that lil thing just a bit so the bar would go in? thanks
Old Feb 22, 2013 | 09:49 AM
tigersharkdude's Avatar
^^my 99 had that same "bracket" that was not holding anything, I cut that thing off
Old Feb 22, 2013 | 10:25 AM
Amerikaner83's Avatar
my 99 didn't have that thing at all But since it's not connected to anything, cut it off or bend it, it doesn't matter.
Old Feb 22, 2013 | 11:23 AM
UniqueMax's Avatar
Lol damn
Old Feb 22, 2013 | 11:25 AM
UniqueMax's Avatar
Anyways I think imma get me a strut bar too..lets see if there's REALLY any difference
Old Feb 22, 2013 | 11:30 AM
Love these old threads
Old Feb 22, 2013 | 05:08 PM
Climaxx's Avatar
1) way to bump a five year old thread
2) original thread went on way longer than it should have lol
Old Feb 23, 2013 | 06:09 PM
GGENIUS's Avatar
^ obvious things are obvious.
Old Feb 23, 2013 | 07:09 PM
asand1's Avatar
Hey guys, is a one piece FBTS better than a three piece TSFB? Do I need tuner lugs after this mod?
