Radiator Help ! Which one would be good and any tips on the job?
Old Feb 16, 2008 | 05:16 PM
FishyMan's Avatar
My radiator has a crack in the inlet area. no matter how I try to sleeve the tube over, it wouldn't work.
I guess I am due to get a new radiator. I"m wondering if the GD for the KOYO radiator is worth the money? It seems like a good deal, but are aluminum rads better or something?
Thanks.
Any tips on doing the job? Does the front bumper have to come out?
Old Feb 16, 2008 | 05:24 PM
pmohr's Avatar
No more Maximas...
They're better at heat dissipation, and you don't have to worry about plastic end tanks breaking or leaking.
Front bumper doesn't need to come off, just remove the two radiator hoses, trans cooler lines (if you're auto), unplug the fan assembly, undo the two brackets that hold it in from the top, and lift out. Personally, when I swapped out to a manual radiator I took the fans off prior to removal of the old, and put them back on after replacement of the new.
Old Feb 16, 2008 | 05:48 PM
FishyMan's Avatar
I'll go w/ the GD and give it a shot. I have an auto. Fan stays in right as the assembly?
*ON clamps. Are the scew type clamps good? My Nissan ones are totally messed up. I guess if anything, I will use the screw types.
Thanks.
Old Feb 16, 2008 | 05:58 PM
pmohr's Avatar
No more Maximas...
Thanks.
I removed it prior to radiator removal just to make the job overall easier, but that's just me.
Regular worm clamps will be fine ()
Old Feb 17, 2008 | 05:20 AM
speed racer's Avatar
or you can get an oem replacement at autozone.
Old Feb 17, 2008 | 10:45 AM
WhiteMaxima9600's Avatar
Go with the gd koyo, i bought one last year and it's fits to perfection. Easy swap just bolt your fan assembly up and drop it in hook up your hoses and fill er up. You will be happy with it.
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
rbuswell
Nov 12, 2016 04:11 PM
pkfinn
Jan 3, 2016 02:55 PM
FlaMark
25
Aug 28, 2015 10:15 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
