Rough Idle in Drive or Reverse (not Park or Neutral)
Old Mar 3, 2008 | 12:38 AM
turbolaw99's Avatar
Hey guys,
Just got my car back from the shop & replaced valve cover and upper plenum gaskets, plugs, pcv, and had intake path cleaned. Car now idles rough when stopped, but only when the transmission is engaged. Engine stutters and RPMs jump in response to stuttering (between 800-650 RPM). This goes away when placed in Park or Neutral, does anyone have any suggestion or experienced this before? Thanks.
Old Mar 3, 2008 | 01:06 AM
Hammy
was the Idle Air Control Valve cleaned?
Old Mar 3, 2008 | 02:12 AM
turbolaw99's Avatar
The IACV was cleaned as well, maybe a replacement is necessary. I just find it hard to believe that it wouldn't idle roughly all of the time.
Old Mar 3, 2008 | 04:07 AM
pmohr's Avatar
No more Maximas...
Likely it does, but when in gear the load on the engine makes it much more noticeable.
Old Mar 3, 2008 | 09:17 AM
turbolaw99's Avatar
I am going to try cleaning it again and then see what the result is, but could there be any other culprit? Does a bad coil pack demonstrate similar behavior? Thanks for the replies.
Old Mar 3, 2008 | 01:51 PM
turbolaw99's Avatar
OK, doing a search outside of the ORG, I found that others experiencing this issue after cleaning the IACV replaced the Throttle Position Sensor (TPS) to solve this problem. Anyone already replaced their TPS? Thanks.
Old Mar 5, 2008 | 03:51 PM
turbolaw99's Avatar
Just following up, but has anyone replaced their TPS and what were the results? I am still experiencing a rough idle after cleaning the IACV. The TPS is ordered but I am awaiting delivery. Thanks.
Old Mar 17, 2008 | 02:51 PM
shorterchild's Avatar
having same issues
Yo turbolaw99, I'm having the exact same problems as you. My car revs at about 700-900 in park/neutral, but only at about 550 and sometimes lower when in gear. It feels like there's a slight chugging at low speeds, but nothing noticeable at higher speeds. I've been told that the TPS is to blame, so I'm thinking about swapping that out. Can you tell me if the TPS fix worked for you? It would really help me out.
Old Mar 17, 2008 | 04:49 PM
Divewjason's Avatar
Sounds like what my Maxima did when it had a bad coil pack. I strongly suggest that you check those. This could save you a lot of fustration in the future.
Old Mar 17, 2008 | 07:57 PM
heynow's Avatar
I've been trying to hunt down the exact problem that shorterchild has described. I've changed all the items that would have anything to do with this problem. That includes IACV/TB cleaning with fresh gaskets, injector cleaning, and swapped coils that came from a maxi with 50k miles. The ONLY thing that hasn't been changed is the TPS, but i'm afraid to touch it because the bolts that hold it are stripped & rusted.
Old Mar 17, 2008 | 08:07 PM
AndrewR2442's Avatar
don't forget the small stuff like the pcv "valve". I have a feeling that's what the culprit is.
Old Mar 17, 2008 | 09:10 PM
jordandalley's Avatar
My car has a bit of a rough idle in D, 2 and 1. It "feels" like the torque converter is engaging too early as its highly eager to get off the line with no acceleration. It idles nicely at ~750 rpm but when it revs, its smooth as.
I checked all my coil packs - all of them were fine. IACV is fine. TPS has been replaced.
I suspect engine mounts are worn and its just excess vibration.
Old Mar 18, 2008 | 10:20 AM
heynow's Avatar
Thanks for the tip, AndrewR. But, i replaced that too. I did everything in the sticky's (and then some).
Jordanalley might be right about the motor mounts. Especially me being a GLE with that electronic front engine mount.
Old May 31, 2011 | 06:08 AM
hthoang0118's Avatar
Hey guys,
Did you received any Code??? Is there any misfired on any of the engine?
1. Make sure the ignition is good. Swap between the two engines to make sure it is not a ignition coil.
2. If it is indeed not a ignition coil, then just unplug the ignition coil which you suspect as a misfired and listen very careful to hear any different with plug and unplug the suspected misfired engine.
3. If it is indeed a different, it might be the fuel injector. NOTE: Please please buy a remanfacture "NOT SALVAGE" from ebay...or junk yard.
4. Good Luck....follow the instruction at YOUR OWN RISK.
Old May 31, 2011 | 06:12 AM
tigersharkdude's Avatar
did you really just bump a 3 year old thread?
Old Jul 23, 2012 | 07:52 PM
Spicylyn's Avatar
I took my 1995 Nissan maxima in fir a smog today and they couldn't do the "Dino" test because when in drive the idle bounces. Any suggestions?
Old Jul 23, 2012 | 07:56 PM
Spicylyn's Avatar
Having trouble with idle in drive
When I took my 1995 Nissan maxima in for smog today they couldn't give my car a "Dino" test because the idle bounced in drive and they couldn't get a reading. Any suggestions?
Old Sep 25, 2013 | 06:08 PM
Aburn95's Avatar
I'm bumping this because I have the same problem. No other suggestions or results?
Old Sep 25, 2013 | 09:26 PM
99maxwell's Avatar
check your map/baro solenoid valve and make sure there isnt any pinched connections going to or from it. had same problem turned out to be a pinched vacuum line attached from it, hope that helps, good luck!
captchaos
Mar 15, 2016 12:18 PM
bryants95max
Oct 2, 2015 12:52 PM
97_GXE
20
Sep 17, 2015 08:12 PM
Maxie40
Sep 14, 2015 11:28 AM
ballerchris510
Sep 10, 2015 09:35 PM
