right Front turn signal will not work!
Mar 4, 2008 | 11:15 PM
My right front trun signal is not working. The back is fine and the left is fine....
Yes all wires are connected, and i have already checked the fuses, and the bulb is new. I tested the wires leading to the bulb harness and there is no power at all going to them, so it is not the bulb harness....
is there any common place in which there could be a short.....
Mar 4, 2008 | 11:30 PM
check the connector first, check resistance of the wires to the bulb- should read 0.1 ohms to 0.3 ohms, if you have resistance between the two wires there is you problem, trace the wires & inspect
Mar 5, 2008 | 08:00 AM
did you do something before it stopped working?
was it working then just went out?
fuse box maybe?
