Belt Adjustment
Old Jun 15, 2008 | 10:42 PM
  #41
arrocha87's Avatar
i wish i had read up on that b4 i dropped $200 for a stock harmonic balancer! damn!
Old Jun 17, 2008 | 01:23 PM
  #42
coachholland's Avatar
As far as bad things about them, I can tell you this. They ship slow. I ordered this thing last Wednesday. They're out of Ohio and I'm in Kentucky. Should take a day or two at the most to get here. The guy I talked to when placing the order said he'd go ahead and get it out for me that day.
I just called them and got a tracking number. They haven't even shipped it out yet.
Old Jun 17, 2008 | 03:50 PM
  #43
kevs95max's Avatar
make sure you tighten everything i had one of my pulleys fall off
Old Jun 17, 2008 | 05:42 PM
  #44
arrocha87's Avatar
yea. i took it to the shop to get aligned and told them to make sure evrytn was on rite and tight and they said i did a good job. lol probably mad they couldnt charge me for anytn! lol
Old Jun 18, 2008 | 09:29 PM
  #45
Sounbwoy's Avatar
New tensioner assembly came today:Hope to install this weekend. Any tips to help make the job easier? There's not much room there as it is...
http://www.flickr.com/photos/sounbwoy/2592155906/
http://www.flickr.com/photos/sounbwoy/2591316703/
Old Jun 21, 2008 | 07:28 AM
  #46
Sounbwoy's Avatar
Originally Posted by MadMaxSE-L
Ok dude, I am going to try and break this down for you to make sure you are doing it right; hopefully I am clear about it. If you are breaking parts trying to adjust belt tension, you are doing something wrong...
So, take a look at the picture below and follow the directions in order;
The following procedure assumes you already have the old belt off and the new one installed, but the tensioner is still loose - BOTH #1 and #2 bolts are loose...
Step 1) Make sure belt is lined up on all pulleys...
Step 2) FINGER tighten bolt #1 and then back it off maybe 1/16th of a turn; just enough to ensure that the pulley will go up and down without issue...
3) begin to tighten bolt #2 so that the pulley is forced down and likewise the belt gets tighter. Do this until the desired belt tention is achieved. YOU SHOULD NOT HAVE PUSH/PULL ON ANYTHING WITH YOUR HANDS TO GET TENSION ON THE BELT. Bolt #2 will do this for you as you TIGHTEN it...
4) Once you have the desired amount of belt tension, tighten bolt #1.
5) Go back and make sure bolt #2 is fairly tight, but do NOT try and tighten it anymore...
It sounds to me like you were trying to tighten bolt #2 when bolt #1 was still tight, and that's why you broke the assembly. Either that or you tightened bolt #2 too far.
I hope that helps,
-Matt
Thanks again to Matt for the assist. I just finished putting the new tensioner on, and everything's gravy once again. Didn't take much time at all. I think my old tensioner was was just that; very OLD (remember original with 289685 miles when I broke it). There are more parts on the new assembly. I've taken pictures and will post them later. If anyone needs a write up, I'll be happy to do it.
Thanks again. The Org is a wonderful place, for those that really need it.
Old Jun 21, 2008 | 03:08 PM
  #47
Sounbwoy's Avatar
I've just posted pictures that I took of the tensioner replacement on Flickr.
Here's the link to my Maxima set of pics. Look for the pics labelled "tensioner.."
http://www.flickr.com/photos/sounbwo...7600904583001/
Old Dec 10, 2008 | 08:49 PM
  #48
steep5's Avatar
On the other hand, when you're done, make sure that you do tighten bolt #1 very tight! I misunderstood plain English, and did not tighten the nut on my pulley, at least, not tight enough. Now my poor old girl is parked at a Target (pronounced: tar-zhay) waiting for the arrival of a new pulley and belt.
Not the first of my boneheaded mechanical failures, and certainly not the last. Someone ask why I would need 9 quarts of oil for an oil change. :P
Old Dec 10, 2008 | 09:08 PM
  #49
pmohr's Avatar
No more Maximas...
How far away is your house from Target? If your battery's got a good charge, you could make it depending on mileage and how you drive. You just wouldn't have an alternator or AC.
Let's see, you left the drain plug out?
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
