New clear tails 97-99 w/pics.
Old Mar 19, 2008 | 09:47 PM
vqmaxman's Avatar
I had to start another one of the threads because there were lot's of Immiture responses by some people here,anyways I have the pics here and I will be asking some people here not to ***** up a thread so It has to be closed Thanks..
Old Mar 19, 2008 | 09:50 PM
vqmaxman's Avatar
I am about to load them up and I will like to ask where and how much should I put the black glue on and I will pointing out the pics to figure If that's where I will be placing the glue.
Old Mar 19, 2008 | 10:39 PM
CRiME's Avatar
oem ftw!
look at your OEM tails and note where the black glue was when you removed them. put it in the same spots on your new tails. Just use your discretion man, there's really no method to it. Think of it this way, imagine the best spots to apply the glue to reduce the chance of water entering the trunk. Put the glue wherever it may seem appropriate to you. Your other thread probably got locked not because of the post whoring but because this is a question that you probably shouldn't even need to ask, and a poster in your other thread basically outlined everything that you need to do to remove and replace the tails. Also if there is anything that you were unclear of as far as swapping tails, there are a ton of relevant threads that you could pull up with the search. Such as this one http://forums.maxima.org/showthread.php?t=69897
Old Mar 20, 2008 | 07:18 AM
G4nismo's Avatar
+1
its not like u apply the glue on the back center of the taillights
its common sense. use your head
Old Mar 20, 2008 | 09:37 PM
vqmaxman's Avatar
Here are the pics of the clear tails. I will also post up some pics when I have completed the Installation.
http://i292.photobucket.com/albums/m...tman85/3-1.jpg
I am planning to start as soon as the crazy cold March weather cooperates.
Old Mar 20, 2008 | 09:41 PM
vqmaxman's Avatar
Originally Posted by g4nismo
+1
I was just making sure that I will be using the glue where The top of tails are because they already have the black strip on top.
Old Mar 20, 2008 | 09:48 PM
G4nismo's Avatar
well if there are already some on there, no need to put anymore. those glue are really really strong. just heat em up until there soft, and install them.
Old Mar 20, 2008 | 10:11 PM
CRiME's Avatar
oem ftw!
yeah, when i installed my red/clears, i actually re-used the existing glue that was there from the old ones, since there was so much of it. also i put some silicone sealant in some spots too (not the one that hardens, the one that dries kind of rubbery - makes it easier if i ever decide to remove them). you can find that at any hardware store. I lined the back side of the tails with this stuff (behind the area of the black weatherstripping and also the bottom part of the tails), basically any part of the tails that would make contact with the vehicle. When I pressed the new tails in they were snug, and I just wiped off any excess sealant that came out.
Old Mar 21, 2008 | 08:31 AM
Snypa's Avatar
i think you should simply pay someone to do this for you.
Old Mar 21, 2008 | 08:38 PM
G4nismo's Avatar
quote of the day!
Old Mar 21, 2008 | 11:53 PM
vqmaxman's Avatar
lol.. ok dude, I can do this myself If I did other mechanical car work I can do this too. I will need to buy out some time and get all the Important things that I have to do then I will start the swaping.
Old Mar 22, 2008 | 11:08 AM
96blackmaxSE's Avatar
boost me.....
BLAAAAAH
boost me.....
BLAHHHHHH
Old Mar 22, 2008 | 11:09 AM
boost me.....
BLAHHHHHHHHHHH
Old Mar 22, 2008 | 01:16 PM
roggeezy's Avatar
dramaqueens.
Old Mar 22, 2008 | 01:43 PM
boost me.....
Hannah Montana/
Apr 16, 2020 05:15 AM
Fbana41
Aug 29, 2016 12:18 PM
Calabar
Oct 5, 2015 09:57 PM
uttadms31
Sep 30, 2015 05:24 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
