Upper perch on rear springs is ****ed, need some sugestions
Old Mar 20, 2008 | 10:06 PM
watut's Avatar
I was trying to take my rear springs off today and on 1 of the bolts holding the perch, the nut is spinning and spinning and its not loosening or tightening. What are my options here?
Old Mar 20, 2008 | 10:15 PM
tallkid2201's Avatar
just buy a new strut mount. the big bushing looking thing on top with bolts.
prolly go to a salvage yard and get it for cheap.
i have to do it for my front....bolt snapped right off
Old Mar 20, 2008 | 10:35 PM
watut's Avatar
thats what i was thinking but how do i get the old one out?
Old Mar 20, 2008 | 10:54 PM
Fr33way™'s Avatar
Wild for Width
You should be able to loosen it on the ground, otherwise vice grip and 14mm wrench.
Old Mar 20, 2008 | 10:58 PM
watut's Avatar
I meant the other 2 bolts that hold it in the trunk. the 12 or 13 mm whichever it is
Old Mar 20, 2008 | 11:01 PM
Fr33way™'s Avatar
Wild for Width
Dremel/cut it from the bottom.
Old Mar 20, 2008 | 11:03 PM
watut's Avatar
# 4 on this
Old Mar 21, 2008 | 12:13 AM
MrDicks95SE's Avatar
Offset Is Everything.
dremel and cut it off. replace with new unit.
Old Mar 21, 2008 | 05:43 AM
njmaxseltd's Avatar
Cut the old one off, replace it with a nut and bolt. (similar to the motavational mounts)
Problem solved for pennys.
Old Mar 21, 2008 | 08:16 AM
Snypa's Avatar
if it wont loosen...cut his-*** off, then replace with new stuff.
Old Mar 21, 2008 | 08:25 AM
watut's Avatar
How do i get a dremel between the mount and the body?
Old Mar 21, 2008 | 11:41 AM
watut's Avatar
Anybody have an extra one for sale from a parts car?
Old Mar 25, 2008 | 04:55 AM
robsst's Avatar
Just ran into a similar problem, replacing the rear struts. Stupid haynes manual had the torque for the mount bolts in 'in-lbs' instead of 'ft-lbs'. I didn't notice, needless to say, the bolt was torqued right off the strut mount.
New strut mount is about $30 from stealership. Couldn't find one at NAPA. Advance auto had one for a couple of bucks cheaper.
Matt93SE
May 24, 2019 02:58 PM
AcuraLegend
Oct 17, 2016 08:47 PM
Huttig2009
Sep 25, 2015 03:31 PM
AcuraLegend
Sep 22, 2015 04:22 PM
homeyclaus
Sep 3, 2015 06:15 PM
