Where is the tire/wheel info listed?
Old Mar 23, 2008 | 09:05 AM
caseymaxima's Avatar
Hey everyone,
I have looked in the "sticky" section, however I can't find the tire/wheel info. What size tires/wheels will fit on my stock suspension 1996 with the 205/65/15's? If I bump up the size, how much will my speedo be off? I have been looking at the 5 spoke wheels from a 99 Maxima, will they directly fit my car?
Thanks,
Zack
Old Mar 23, 2008 | 09:24 AM
Snypa's Avatar
well i understand you checked the sticky section,but you gotta make sure your in the wheel forum then go to the sticky section.
http://forums.maxima.org/forumdisplay.php?f=53
look to the top, you will se sticky.
Old Mar 23, 2008 | 09:48 AM
I guess I am dumb, but I still can't find out what fits for my 96 with the 205/65/15's.. There is a seller in NJ that has stock tires and wheels from his 1999 SE. I checked the tirerack.com site and they list the 99 SE size as 215/55/16's, is that correct? Will those directly fit my 1996 without any mods at all, I want a bolt up and go set up. Will my speedo be off much?
Thanks,
Zack
Old Mar 23, 2008 | 10:07 AM
BLACKonBLACK98's Avatar
Former Vendor
seriously? you want to know if stock wheels/tires from the same generation will fit?
Old Mar 23, 2008 | 11:00 AM
Seal89's Avatar
type "tire size calculator" in google and just enter your numbers you'll see!
Old Mar 23, 2008 | 11:49 AM
Yeah, it's a much bigger tire/wheel
Zack
Old Mar 23, 2008 | 03:47 PM
ROCKART's Avatar
wants an I35
http://www.1010tires.com/TireSizeCalculator.asp
or if you wanna get fancy
http://www.rims-n-tires.com/rt_specs.jsp
Old Mar 23, 2008 | 07:20 PM
Thanks everyone, I checked the tire size calculator, and the speedo will not be off much at all. But it still does not answer the question if they will fit on my 1996. Will the wheels clear the calipers? Is the bolt pattern the same? HAs anyone else done 1999 SE wheels on a 1996 GXE?
Thanks,
Zack
Old Mar 23, 2008 | 07:21 PM
ROCKART's Avatar
wants an I35
yes man
the bolt pattern is the same
and i dont know if you have a BBK, but if you have stock calipers they will be fine
90% of all nissan wheels are interchangeable. with the exception of sentras and 240s and econo sizes like that.
murano = 350x = g35 = m35 = all levels of nissan
Old Mar 24, 2008 | 06:10 AM
Originally Posted by ROCKART
yes man
Thanks! This is the info I needed!
Zack
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
worldwiderecognized
Sep 30, 2015 01:16 PM
