Horrible Startup Problem With My Max!!!Please Help
Old Oct 31, 2001 | 07:39 PM
maxperformance's Avatar
I went to go start up my 1995 Maxima tonight, and it was COMPLETELY DEAD! My radio and ac came on so it wasnt the battery. The engine made no attempt whatsoever to startup. It did sound like it "turned over" It must be a broken fuse or something or that sort, maybe electrical. Maybe somehting with my ignation switch. I called AAA and they tried jumping it and they had no clue. I had it towed to a shop. Why is my max totally dead. i need immidiate feedback. Thank you so much
maxperformance
Old Oct 31, 2001 | 07:55 PM
BRIGBOY's Avatar
What else.
Does the starter turn over, or is it dead to. If the starter doesn't go it is dead. Tell us more.
Old Nov 1, 2001 | 01:03 AM
vmok's Avatar
Re: Horrible Startup Problem With My Max!!!Please Help
maxperformance
If the lights and everything else came on, it could be the neutral/park switch on autos or the clutch interlock switch on the 5sp. Do you have any kind of car alarm installed?
-V
Old Nov 1, 2001 | 05:12 AM
Re: Re: Horrible Startup Problem With My Max!!!Please Help
-V
I do have an automantic. . .and i tried switching the gears and starting it in neutral. I dont know what the problem is. I only have the stock security system on the max. It could be that . .maybe a fuse.
Old Nov 1, 2001 | 05:13 AM
Re: What else.
The starter does not make any attempt what so ever to turn over. Its just useless. I sent it to a mechanic. No feedback from him yet. what is wrong :-(
Old Nov 1, 2001 | 06:56 AM
BRIGBOY's Avatar
The starter went on my 95,
same things you describe. If its not cranking its dead.
Old Nov 1, 2001 | 07:20 AM
Eric L.'s Avatar
Re: Re: What else.
Sounds like either the neutral position switch or the starter solenoid has gone bad. You've already left the car at the shop, so relax....it will get fixed.
matts95max
Apr 23, 2025 10:44 AM
pktaske
May 6, 2016 07:49 AM
captchaos
Mar 15, 2016 12:18 PM
MaxLife17
Sep 8, 2015 02:36 PM
pktaske
Sep 4, 2015 08:40 AM
