Pros/Cons of Mud Flaps / Rain Guards
Old Apr 29, 2008 | 05:02 PM
97maximany's Avatar
Hello to all , as you can see I am new here, purchased a 97 max se don't know the miles because it does not have white gauges....
I search for hours but unable to find a answer.....SPlash Guard / mud flaps will this effect handling in the rain.....I would image that they prevent the rain from properly exiting off the tire.......? Don't know if I should take them off for safety reasons
Old Apr 29, 2008 | 05:11 PM
ZX9RBART's Avatar
The flaps are a good 2 to 3 inches from the tire minimum, plus the fact that they are behind the tire leads me to believe there is no possible way they could block water from effectively exiting the tire. Hydroplaning occurs when water is trapped under the leading edge of the tire.
Old Apr 29, 2008 | 05:35 PM
xenomax's Avatar
the next time it rains take your car for a road test and see what it feels like. then go home and remove the splash guards and roadtest again. i think you wont notice any difference but who knows. please report back with your findings.
Old Apr 29, 2008 | 05:40 PM
Turbobink's Avatar
Originally Posted by 97maximany
...don't know the miles because it does not have white gauges....
So what exactly does having white gauges have to do with knowing the car's mileage? I don't have white face gauges in a couple of my cars but I still know the mileage.
Splash quards have been installed on cars for decades. Multitudes of makes and models either come off the showroom floor with them or get them installed after market. Not sure I've ever heard of a recall, TSB, or safety advisory related to hydroplaning or any other traction related issue(s) caused or contributed to by a splash guard.
Old Apr 29, 2008 | 06:10 PM
97maximany's Avatar
The reason I say I don't know the milage is because I have a SE and I thought they only came with white gauges. So Iam under the impression they switch the cluster . The clock say 118,000 but I doubt . So I'll be looking for the proper cluster.....Good call ..I will take it out in the rain with flap and without. I will post the results. But think about it....When your behind a max or car without flaps look how much water is exiting as appose to a car with. How could it be the same.
Old Apr 29, 2008 | 06:17 PM
ZX9RBART's Avatar
Because the water is being deflected down and to the sides as opposed to straight towards the rear...yet it is still behind the tire where it makes no difference.
Old Apr 29, 2008 | 06:29 PM
black_maxed95's Avatar
correct, only SEs came with white gauges and SEs only came with white gauges, therefore the cluster was swapped at some point. A carfax report might give a better idea on the real milage but most likely you wont find out unless the person you bought it from knows and tells you.
about your flaps...they arent gonna hurt handling, they just keep your car a little cleaner. I wouldnt waste my time testing the car in the rain.
Old Apr 29, 2008 | 06:36 PM
LeVeL's Avatar
flaps have absolutely no effect on handling
Old Apr 29, 2008 | 06:40 PM
slow97maxima's Avatar
member
cmon guys saying mudflaps make a handling difference might be the stupidest thing i have ever heard
Old Apr 29, 2008 | 06:46 PM
ZX9RBART's Avatar
I'm new to the forum so I tried to say it nicer than that.
Old Apr 29, 2008 | 07:01 PM
tallkid2201's Avatar
if you dont want flaps ill take em off ya
Old Apr 29, 2008 | 07:47 PM
roggeezy's Avatar
Does my antenna affect the drag on my carr??????????
Old Apr 29, 2008 | 08:06 PM
icaghost's Avatar
ive done many tests and my 0-60 is most def at least half a second shorter with antenna down...that **** creates drag like none other
Old Apr 29, 2008 | 09:00 PM
f550maranello2's Avatar
yea so does taking a dump right before u go to the track....
Old Apr 29, 2008 | 09:07 PM
Snypa's Avatar
wow, that skinny **** shiny thing.!!!!
Old Apr 29, 2008 | 09:14 PM
99BlackMaxMS's Avatar
HAHAHAHA
What is going on in the 4th gen forum?
Old Apr 29, 2008 | 09:29 PM
Snypa's Avatar
Originally Posted by 99BlackMaxMS
HAHAHAHA
LOL...i have no clue.
Old Apr 30, 2008 | 04:07 AM
LeVeL's Avatar
HAHAHAHA
The n00bs stopped going to the n00b thread
Old Apr 30, 2008 | 06:34 AM
97maximany's Avatar
I don't mean handling like the way you guys interpet, but performance in the rain. Who thinks there no diffrence in hydro or better traction YOUR WRONG. I did test last night and I felt a good not major diffrence with them off. I took video with and without the flaps and you could see clearly the amount of water exiting away from the car. I have other question , I hope this one is not stupid also.
Old Apr 30, 2008 | 06:38 AM
Snypa's Avatar
^^....well if thats the case, leave em on man. GL.
Old Apr 30, 2008 | 06:49 AM
ROCKART's Avatar
wants an I35
the water is being thrown from the tire
whether it hits a flat piece of plastic or not is irrelavent. the flaps will keep your car cleaner. that is it.
then again, the mudflaps add about 0.7 lbs to your overall weight, so you might want to think about that.
Old Apr 30, 2008 | 07:01 AM
Coolsaber57's Avatar
I thought that the mudflaps/rainguards were supposed to keep your car from throwing water and mud and crap out out of the back and hitting other cars.
Old Apr 30, 2008 | 07:06 AM
97maximany's Avatar
Nobody is talking about speed or weight. Its a saftey question.. And for anyone here talking about making a MAXIMA FAST LOL .....your in the wrong forum....Get yourself a sports car. But thanks to the guys who responded.
Old Apr 30, 2008 | 07:20 AM
LeVeL's Avatar
If you think a max without mud flaps kicks up a lot of spray, try driving behind a semi in the rain.
Old Apr 30, 2008 | 07:31 AM
member
Are you serious? I cannot believe you are still arguing this! If you think you don't hydroplane and have better traction without mudflaps, then fine dont use them. But it's all in your head....
Or maybe you are right and Nissan added mudflaps as a way to deminish the safety of people on the road
Snypa's Avatar
yeah...lets see you do that.drop you sunroof/windows too.
Old Apr 30, 2008 | 07:35 AM
there are plenty of fast maximas here. plenty of 4th gen 300hp+ and a few 400hp+ on these forums.
I tried to be nice earlier, but now I think you are clearly in the wrong forum, there is a noob thread for you.
Old Apr 30, 2008 | 09:57 AM
duh havnt you heard of 4DSC? lol
Old Apr 30, 2008 | 10:23 AM
IlyaK's Avatar
The Golden One
Seriously...I'm pretty sure Nissan considered this when they....*gasp*...DESIGNED THE MUDFLAP.
Old Apr 30, 2008 | 10:46 AM
hot_wax_tree's Avatar
you need to leave or get a brain. stop being so dumb.
I cant even tell if this is for real any more.
Old Apr 30, 2008 | 10:55 AM
Turbobink's Avatar
Originally Posted by funkmasta
i think mudflaps look dumb
Hey!.. we're not talking about looks here people... were talking about safety and safety comes first and foremost.
I think we must all take heed of the questions posed by our bretheren here. I think we should all remove and discard our splash guards... pass it on everyone. Let's make next Friday, May 9, 2008, No More Mudflaps Day!!
Notwithstanding the fact that the channeling of water away from our tires is dangerously inhibited by the presence of these insidious little devices, I am absolutely certain that upon reaching a speed of 326.27 mph these mechanisms of mass destruction will most assuredly cause our vehicles to take flight.
Pass it on everyone. Pass it on.
Where the hell is Ralph Nader when you really need him?
Mr. Maximany, sir... you need to stop talking out your butt. Your breath is offensive.
Old Apr 30, 2008 | 11:00 AM
IHAVEA2KMAXIMA's Avatar
Lucky there's no antenna drag for 5th gen! There was one of the major factors that I got a 5th gen instead of 4th. Glad I made the right choice with the more aerodynamic antenna drag free 5th gen!!
Old Apr 30, 2008 | 11:10 AM
97maximany's Avatar
Dude number one I didnt disrespect anyones opinion or this forum. I simpley asked a safety question.....U people ran with the punches and kept it going. I thought it was a honest question. sorry I didnt ask something more important. Again I ask a safety question.
Old Apr 30, 2008 | 11:19 AM
ROCKART's Avatar
wants an I35
Old Apr 30, 2008 | 12:16 PM
LeVeL's Avatar
I can't tell if you're being sarcastic or not... I sure hope you are
Old Apr 30, 2008 | 05:24 PM
Snypa's Avatar
Originally Posted by ROCKART
yep ^^^
Old Apr 30, 2008 | 07:31 PM
First off I would officially like to welcome you to the forums. you are inexperiencing the life of a noob who asks a question that is not so smart. CONGRATULATIONS
Secondly there was no secondly after your firstly.
nice to meet ya.
Old Apr 30, 2008 | 07:51 PM
flyby's Avatar
i think the mudflap mainly helps keep the *mud* offf your car in certain situations ...oh and it adds bout 5 hp
Old Apr 30, 2008 | 08:10 PM
Blackwind's Avatar
i will bring Big Nutts McGurrdy into this if i have to.
Old Apr 30, 2008 | 08:14 PM
Blackwind's Avatar
This post has been brought to you by: "WTF! That's right WTF! Scientificly desgined to keep you guessing or your money back! Now available in "Stupid Noob!"
