a lot of free time + dremel
Old May 13, 2008 | 08:10 PM
G4nismo's Avatar
decided to make a switch panel for auto-x and track purposes. also played around w/ the climate control and changed the shifter ****. i will add a boot for it whenever i have time.
wired the o/d, high/low manual rad fan, speed limiter removal, and the DR with still keeping the WOT switch. (thanks tatanko for the tip)
i will make another panel once i get my hands on the suprastick whenever that might be.
know it looks like crap but it works
Old May 13, 2008 | 08:11 PM
G4nismo's Avatar
disregard the ancient tape/radio deck, going to get a new 1 soon
Old May 13, 2008 | 08:15 PM
IHAVEA2KMAXIMA's Avatar
What? You're getting a newer cassette player?
Old May 13, 2008 | 08:22 PM
roggeezy's Avatar
how do you live with just a cassette/radio player!!!
props to you for doing it yourself! I might borrow that idea for my accent lighting switches.
Old May 13, 2008 | 08:27 PM
BLACKonBLACK98's Avatar
Former Vendor
i'm working on something similar (different pupose). 6 buttons and 2 gauges molded in using abs. it sill has to be filled, sanded, and dipped but should look oem when i'm done.
Old May 13, 2008 | 08:33 PM
99BlackMaxMS's Avatar
Holy crap, how can you live with that POS headunit?
Old May 13, 2008 | 09:29 PM
Crooper_Hedder's Avatar
The switches are kinda ghetto IMO especially considering the upgrades you've done to your dash and shift ****. Lighted LED rockers would probably look a little more stylish.
And cool HU man, I used to have that in my Nissan Pickup. :-)
Old May 13, 2008 | 11:14 PM
Snypa's Avatar
i love the idea. So what mode were you in...post#2 2nd picture.?
Old May 14, 2008 | 05:16 AM
ruckus1027's Avatar
dude i bet he has the tape adapter thing so he can listen to his mp3 player...id rather have that than an amfm transmitter...
Old May 14, 2008 | 07:43 AM
G4nismo's Avatar
looks sweet! good luck on it!
just never really cared about listening to music that much. the radio did just fine but now i'm kinda getting annoyed b/c the display won't even work. yes, i'm a cheap ***
don't know how the switches look ghetto to you. i didn't wanna go w/ the cheap, giant plastic switches at radio shack so i got these at autozone. i think they look fine, whatever. the lighted LED rockers i wanted were absolutely expensive, nearly $10 a switch and they only had SPST.
DR activated, center off for rad fan, and speed limiter turned on
used to have one but that doesn't even work now. once i put the tape in, almost 90% it never pops back out, so i never use it.
Old May 14, 2008 | 04:14 PM
The Russian's Avatar
nicestuff
Old May 14, 2008 | 04:45 PM
f550maranello2's Avatar
man what kind of ghetto wiring is that..
Old May 14, 2008 | 05:19 PM
G4nismo's Avatar
i just used those different color tape to distinguish from other wires. i didn't actually wire all my other connections like that.
Old May 14, 2008 | 06:26 PM
kcryan's Avatar
This is how i did mine:
Old May 14, 2008 | 07:11 PM
black_maxed95's Avatar
and what do these buttons do?
Old May 14, 2008 | 07:16 PM
kcryan's Avatar
Green turns fire dept radio on/ off
Red turns Valentine V1 and concealed display (in where the clock used to be) on and off
Blue turns LED Blue emergency light behind rear view mirror on and off
Old May 14, 2008 | 07:20 PM
Tatanko's Avatar
Bacon Lover
Hmmm...good work! I like how the **** looks. Usually aftermarket ***** look stupid like that, but I like it. Is that the same "Redline" **** I have on my car?
Also, you will be getting PM
Old May 14, 2008 | 08:21 PM
G4nismo's Avatar
yeh, its the same one u have. all the other ones didn't really suite my tastes so this was the best candidate. i'm gonna make a boot just for the shifter, not covering the prd21 display. basically what olezhka did for his.
Old May 15, 2008 | 04:23 AM
Tatanko's Avatar
Bacon Lover
I've considered switching back to having a PRND display, but I'm just so lazy that I can't make myself do it
Old May 15, 2008 | 08:05 AM
G4nismo's Avatar
pshhhhhh, you've done an 00VI swap, don't even complain about being too lazy for this
Old May 15, 2008 | 12:12 PM
IlyaK's Avatar
The Golden One
That's fricken awesome man.
Old May 15, 2008 | 01:12 PM
ptatohed's Avatar
Licensed to Spell
I like the idea/concept but for some reason something doesn't look right. That frosted black plastic that g4nismo and kcryan use doesn't match anything OEM, and it looks out of place being an "island" (g4nismo has his surrounded by silver, kcryan has his surrounded by wood). Could you guys make silver/wood (respectively) panels instead of using that black frosted stuff?
Old May 15, 2008 | 02:19 PM
Tatanko's Avatar
Bacon Lover
Increased performance was a motivator there. What motivation do I have here?
Old May 15, 2008 | 05:36 PM
G4nismo's Avatar
the motivation is so that you won't have to explain to people that its not a true manual
Old May 15, 2008 | 05:42 PM
Tatanko's Avatar
Bacon Lover
You know what's sad? People will get in the car with me and I will drive around for a while with them in the car, and THEN they ask me if it's a manual. "Yes...it's a a manual. I drive in 4th gear all the time, I never shift or use any of the other gears" (referring to the fact that it sits in the D postion).
Old May 15, 2008 | 07:07 PM
G4nismo's Avatar
then they'll ask you what all those buttons are on your dash board. (referring to the shift_fast buttons). and you can't lie about them!!!
Old May 15, 2008 | 07:16 PM
khantalha+'s Avatar
Nice man, Great work!
Old May 15, 2008 | 08:55 PM
kcryan's Avatar
Thanks man, it works... quite well
Thought about wood, i've got a ton of wood in my house, but none of it, actually scratch that, no real wood anywhere, matches the stuff in my car, the black might not look factory, but it gets the job done decently well, and looks better than having 3 plugs into my cig lighter. That said if anyone knows where i could get a faux wood piece real cheap, i might be intersted...
I'll see if i can get some updated pics with the V1, the concealed display, the radio and the light.
Old May 15, 2008 | 10:53 PM
95arcticpearl's Avatar
That panel looks real good...I'm looking to do the same for my car with 4 switches. The switches are going to be for fire dept emergency lighting where i plan on setting up one as a master switch and the other three to control front windshield and grille, rear window and strobes individually. I was planning on using a peice of arcylic and just painting it black but I'm trying to think of other possible options also.This may be a stupid question but what is the black plastic and where did you get it?
Old May 16, 2008 | 06:36 AM
G4nismo's Avatar
nah its fine. its just an abs plastic sheet that i got off of ebay. it was only like $12 or so. i got the 12x12x1/8 but now that i've done this, i would of gotten the thinner one, the 1/16 instead.
vingodine
45
May 21, 2016 12:46 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
mikekay
Aug 10, 2015 12:52 PM
