DEK swap 80-90% complete
Old May 21, 2008 | 03:26 PM
93altima's Avatar
Turbo 4th Gen
iam almost done my DEK swap the motor is mounted trans is in y-pipe connected all electrical connectors is on. i cranked the car and it came on but it only stays on using starter fluid i think i ran my fuel line correctly and iam not so sure about my vacuum job but IT CRANKED now all i have to do is put the axles in and set the car on the floor and figure out the fuel and if the vacuums are ran correctly
Old May 21, 2008 | 03:37 PM
Product_Of_Korea's Avatar
did you check out the fuel pump fuse??
Old May 21, 2008 | 06:36 PM
93altima's Avatar
Turbo 4th Gen
i hear the fuel pump prime when i turn the key on but ill check it in the morning
Old May 21, 2008 | 07:08 PM
eh then it probley is good. it is possible that you might have your fuel lines on backwards. i made that mistake when i did my vi swap.
Old May 21, 2008 | 09:45 PM
93altima's Avatar
Turbo 4th Gen
ok theres 2 fuel line one is coming for the fuel filter and the other line is coming out from around the fuel filter right?>?? i got the one coming from the FF on the FPR closest to the TB and the other oner one to the FPR closest to the Radiator right???
Old May 22, 2008 | 04:42 PM
93altima's Avatar
Turbo 4th Gen
ok iam about 95% done iam driving it right now its idling up and down but besides that it drves fine how do i stop the idling problem?
Old May 22, 2008 | 04:49 PM
bigshaunsmax's Avatar
i dont wanna sound like a moron, but what is the dek swap
Old May 22, 2008 | 04:57 PM
93altima's Avatar
Turbo 4th Gen
taking a motor from a 00-01 maxima (VQ30DEK) and putting it in a 95-99 Maxima thats come with a VQ30DE
Old May 22, 2008 | 05:00 PM
yea i guess using the engine code makes sense, what kind of a difference does it make power wise
Old May 22, 2008 | 05:10 PM
KRRZ350's Avatar
^^ Read the stickies and search. '00vi and you'll find stuff in the all motor forum, but please don't post much in there 'till you know the ropes.
Old May 22, 2008 | 05:11 PM
KRRZ350's Avatar
TPS or vacuum leak tends to cause that problem.
Old May 22, 2008 | 05:28 PM
+1
also did you use the 5th gen iavc? i would pull out the sensor and check the o-ring that goes around it. did you hack off part of the sensor to make it fit?
also out of curiousity what did you do to figure out your fuel problem?
Old May 22, 2008 | 05:45 PM
93altima's Avatar
Turbo 4th Gen
^^^^^yea i had the fuel lines switched lol but i used the 5th gen tb with the iacv i cut the plug and turned it upside down to go in but besides that the gar is running and i think i feel a diffrence??? i say that because when i did the swap i didnt get a new clutch and my old clutch is BEAT so it slips almost every time i ran outta funds while doing the swap (times are hard)
Old May 22, 2008 | 08:13 PM
maxkid123's Avatar
hahaha i think that happens to everyone doing the dek swap...it happened tooo me it had me sooo frustrateddd...couldnt figure out what the heck was wrong...then i took a look at my fuel lines and found it that they were on backwards hahaha....
Old May 22, 2008 | 09:42 PM
93altima's Avatar
Turbo 4th Gen
damm now i just got to figure out my idling problem and how to hook up the safc2 to control the vias and iam good
Old May 22, 2008 | 10:23 PM
DrunkieTheBear's Avatar
Turbo'd Saab
A simple test to check for vaccum leaks...
-duct tape the the throttle body closed
-make sure all vaccum lines are either caped or running to the proper place
-take the main vaccum line in the back left side of the IM and blow
Listen for the leaks...and go from there
Old May 22, 2008 | 10:29 PM
93altima's Avatar
Turbo 4th Gen
will do sir
James92SE
142
Jan 2, 2024 09:23 AM
Mar 12, 2020 12:06 AM
Socalstillen
Sep 20, 2015 11:46 PM
Bonka
Sep 14, 2015 11:18 PM
I<3 A32's
Sep 10, 2015 11:07 AM
