can't adjust rear height on coilovers
Old Jun 4, 2008 | 10:10 AM
G4nismo's Avatar
did some maintenance (i know so surprising), tuning and raised it a bit up front yest on the ksports cough, cough...so i figured i do the rears the next day.
i wanted to lower the rear but i couldn't loosen the lower, i guess you could say the long orange collar. therefore, i couldn't actually adjust the height. whenever i tried to loosen it, the whole shaft would turn, which does nothing for the height adjustment. what is the best solution you think to loosen that collar?
Old Jun 4, 2008 | 10:50 AM
IHAVEA2KMAXIMA's Avatar
aren't you suppose to use one wrench to hold it in the opposite direction while using the other to loosen it, so the shaft wouldn't turn?
Old Jun 4, 2008 | 12:08 PM
G4nismo's Avatar
i don't know what your talking about. are you referring the two collars near the spring perch?
theres only 1 lower strut bolt and 1 collar screw that holds the lower section.
i loosened the bolt and the collar but the piece between the collar and the bolt won't move.
Old Jun 4, 2008 | 12:16 PM
bigpulve+'s Avatar
flat head screwdriver, a hammer and some WD 40......or you may have to take off the whole assembly....
Old Jun 4, 2008 | 12:28 PM
G4nismo's Avatar
what would be the point of the flat head and a hammer? i'm not trying to loosen the collar.
Old Jun 4, 2008 | 12:50 PM
bigpulve+'s Avatar
oh I thought you couldnt loosen the collar....
My guess is take off the strut and spray some WD 40 into it and try and get it loose that way....off the car it should be easy.
Old Jun 4, 2008 | 12:51 PM
EnervinE's Avatar
i has college
Vice grips are (almost) always your friend.
Old Jun 4, 2008 | 12:53 PM
G4nismo's Avatar
well the long orange shaft thing that i'm trying to loosen is frozen solid.
Old Jun 4, 2008 | 12:54 PM
G4nismo's Avatar
my vise grips arn't deep enough to grip around the shaft. plus i don't want something w/ metal teeth that'll imprint it on the thread.
maybe i'll look at a hardware store for something with a plastic or rubber grip
Old Jun 4, 2008 | 12:57 PM
EnervinE's Avatar
i has college
Ahah, I called them vice grips. doh. I wrap the inside of mine with a rag and they never leave a mark. Although I wouldn't trust them working on a threaded surface, like you said...
I know I saw a tool at Sears once made for working on a threaded surface (had a rubber jaw) but it was rather small. Take a look around.
Old Jun 4, 2008 | 01:17 PM
G4nismo's Avatar
yeh i just called ksport and they said sometimes the aluminum protective additive or whatever thats applied on the shaft tends to wear off, thus causing it to lock up.
sigh...i just spent 2 hours trying to loosen that stupid thing and didn't end up lowering anything. totally a PITA
Old Jun 4, 2008 | 02:27 PM
Flava_24/7's Avatar
Boosted Panda
Wow, yet another issue with K Sports. Sorry bro.
Old Jun 4, 2008 | 02:30 PM
WhiteA32's Avatar
LOL, well its better then just lowering one side because it was easy, and then moving to the other side just to find out its way to tight/seized...haha
But yeah try the WD40
Old Jun 4, 2008 | 02:34 PM
G4nismo's Avatar
yeh, i raised both the fronts in 45 minutes but spent 2 hours on 1 of the rears trying to loosen that thing . wish i had gone w/ teins or D2's
Old Jun 4, 2008 | 02:49 PM
WhiteA32's Avatar
LOL Back in January it took me 1 hour to drivers side front.
Like 2.5 weeks ago it took me like 1 hour to do drivers rear, I still haven't made it around to pass rear hopefully this week
Old Jun 4, 2008 | 05:13 PM
G4nismo's Avatar
jeez 1 hr to do just the driver side front? what are you doing, drinking a beer, eating chips while your doing it?
Old Jun 4, 2008 | 06:02 PM
WhiteA32's Avatar
hahaha no, I tried to lower it, lowered it, put the tire back on, found out it wasn't low enough and I had to rinse and repeat... until I found out you can measure the distance from the collar to the end of the threads...hehe ooops
Old Jun 4, 2008 | 06:41 PM
G4nismo's Avatar
yeh, thats what i did. saves a whole lot of time and headaches
Old Jun 4, 2008 | 07:26 PM
BLACKonBLACK98's Avatar
Former Vendor
how were you trying to turn it? i assume its frozen but just to make sure: you used the wrench on the spring perch with the upper locking ring in place and the lower locking ring loose right? not sure how ksports are put together but if they are frozen the shaft should not move at all rather than turning the whole assembly.
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
BkGreen97
Apr 2, 2016 05:47 AM
doctorpullit
Sep 10, 2015 06:33 PM
ef9
Sep 5, 2015 11:18 PM
